I recently found out that MMC appear to have discontinued the speed sensor that is fitted to the M3W (5-Speeder) and +4 Duratec.
![[Linked Image]](https://tm-img.com/images/2024/12/22/Photo-1--Speed-Sensor.png)
On the M3W, this sensor is fitted through the right hand front brake calliper bracket. As the hub rotates, five bolt heads pass closely by the head of the sensor, thus creating 5 pulses per rotation and this signal is subsequently converted into the speedo reading.
MMC have superseded the sensor with this type:
![[Linked Image]](https://tm-img.com/images/2024/12/22/Photo-2--New-Type-Speed-Sensor.png)
It’s MMC part number E221002 and as you can see it is quite different to the original one, having an integral socket. To compound the problem, the original loom connector needs replacing as it isn’t compatible with the new sensor.
I therefore set about making a replica of the original type. This has a 5 Inch (125mm) lead leading to an Econoseal plug, with a ‘pull-up’ resistor between the sensor output signal and +5V.
![[Linked Image]](https://tm-img.com/images/2024/12/22/Photo-3---Schematic.png)
Once I had sourced the components and the special crimping tool needed for the connector pins, I assembled the assembly with a suitable amount of heat-shrink sleeving to make it as waterproof as possible. I have to say that it was a bit of a fiddle, especially having to incorporate the resistor into the plug.
I’ve often thought that having the sensor connector adjacent to the lower wishbone where it is guaranteed to be exposed to copious amount of water and muck from the road is not one of Morgan’s most inspired decisions (and doesn’t look particularly attractive either). Indeed, when I took my original connector apart, there was evidence of corrosion on the pins, even though the connectors are nominally waterproof.
Therefore, I am also making up a long-lead version of the speed sensor which has a 1 Metre lead. Once the existing loom has been unclipped from the lower wishbone, it can be fed back up to the area below / in front of the oil tank, adjacent to the red +12V post. The lead from the ‘long’ sensor is then run along the lower wishbone and fed up behind the chassis tubes to the new connector position. The plug, socket and ‘spare’ cable can then be tucked under the transverse chassis tube and held in place with a couple of tie-wraps. Obviously, this is a bit more involved to fit but does result in a much neater installation and a more appropriate position for the electrical connector.
When I removed the original sensor from my car, there were witness marks on the sensor head where it had come into contact with one or more of the hub bolts.
![[Linked Image]](https://tm-img.com/images/2024/12/22/Photo-5--Witness-marks.png)
The sensor spec calls for a clearance of 0.3 – 2.3mm between the sensor and trigger so I sourced a 1mm thick shim washer which can be fitted between the sensor mounting flange and the brake calliper bracket to increase the clearance if necessary.
The original sensor retaining screw is a button-head type, needing a 5mm hex key to release. Mine was quite corroded so I replaced it with a stainless steel cap-head type requiring a 6mm hex key. This should make it easier to remove in the future if it ever needs to be replaced again.
This is the 'short-lead' kit:
![[Linked Image]](https://tm-img.com/images/2024/12/22/Photo-6--Bunny-short-speed-sensor-showing-kit.jpeg)
The ‘long -lead’ kit is similar. However, in order to release the loom from the lower wishbone, three P-clips need to be removed. Therefore, this kit also includes 3 replacement black pop rivets for reattaching those clips as well as some tie-wraps to finish off the installation.
If anyone is interested in one or other of these sensors then please PM me as I’m going into limited production! These are listed in the ‘For Sale & Wanted’ forum
HERE.
