5 members (John Winn, Carbuilder, Davetherave, RichardV6, IcePack), 264 guests, and 31 robots.
+8Rich 96
John V6 51
Topics49,901
Posts838,043
Online NoMood
Originally Posted by Rog
Please let me share another perspective Richard smile
Heat is the number one enemy or killer for LED's. LED life is directly related to temp. After market canbus friendly LED's bulbs are designed to mimic filament bulbs so may have a load resistor poked up the back. Typically the resistor will need to dissipate around 20w. That's an awful lot of heat in a tiny package. For the life claims manufacture's thermally mitigate the heat load using cooling fins on the bulb package, limiting the LED brightness or wattage and calculating life based on a typical shortish indicator duty cycle. However, should you ever need to leave your hazards on for and extended period, all bets are off for the poor old LED's....
Useful point Rog. In fact they don't seem to draw current equivalent to the full 21 watts of the filament bulbs they replace, according to Duncan at ClassicCarLEDs. Furthermore I'm using CANBUS friendly switchback LED's in the front with the white elements on continually, except when indicating.
Not sure how this is managed thermally but no signs of massive heat sinks showing on the switchbacks I'm using above. These have been in for close on 20,000 miles now with no issues.
Having said all this I do recall mention of avoiding leaving hazards on for extended periods with some of the LED variants.
Regarding need for rear visibility during daytime, each to their own. For me having seen how difficult it can be to see cars in dull or murky conditions rear lights on are a must.
BigLes Offline OP
The job is done. The new headlights are installed and the DRL LEDs are working fine. Thanks for the tips and advice.
Roadster 3.7
Plus 4 110 Anniversary
Plus 4 Fiat TC
Rog, you still have the cobra brake light that comes on to attract drivers behind you without the confusion of the tail lights being on.
Rog Offline
I take your point Sewin but I'm going to need more convincing... smile
I've got rear fog lights and manual lights for the 1% of time when visdibilty is poor. So I struggle to see the rationale of keeping the rear lights on all the time and in bright sunlight too! I need all of my brake warning lights to be as noticeable as possible, particularly if being followed by an artic truck.
Regarding the cobra light though I do actually like it a lot. I've often pondered on adding a stobe. Only for use on the few occasions I use the motorway. Don't know how legal they are but I'm sure it could improve one survival odds.
PS - sewin if you are ever thinking about a career in sales, let me know thumbs
Roger
Don't some modern tin-tops pulse the brake lights / hazzards (all indicators) if you brake really hard ??
