Posts837,996
Posts: 33 |
Hi
After ten years of use my door checks are no longer holding my doors open.
Has anybody had this issue and how did they resolve it?
Many thanks
Andrew
2015 Lapis Blue Roadster 1972 British Racing Green MGB Roadster
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
I've used a set of water pump pliers. Put a chunk of rubber on the jaws to protect the metal and then squeezed the two sides of the door checks together.
1 member likes this:
RichardV6 |
Posts: 27,836 Likes: 761
Posts: 27,836 Likes: 761 |
You can replace the clear tube that the bolt passes through
Posts: 2,095 Likes: 75
Posts: 2,095 Likes: 75 |
You can replace the clear tube that the bolt passes through Or even turn it upside down?
Posts: 834 Likes: 28
Posts: 834 Likes: 28 |
or rough it up with sandpaper?
1993 T16 +4 Lancia Blue.
Posts: 33 |
Many thanks for your replies.
Andrew
Posts: 1,031 Likes: 120
Posts: 1,031 Likes: 120 |
Yep, Bend it back into shape!
