2 members (MATTMOG, DCH),
276
Posts837,994
Posts: 5,594 Likes: 612
Posts: 5,594 Likes: 612 |
Howard ... if you hold the boat wheel at the bottom all resolves itself! 🙂
Posts: 11,535 Likes: 321
Posts: 11,535 Likes: 321 |
Got an axe to grind here. Nothing to do with Morgans or at least not specific to Morgans. We have 3 cars and all of them have different stalks and gear selection locations. The framily Merc has the most stupid of the lot because the gear "lever" is a normal stalk to the right of the wheel and where one other car has its indicators and the third has its wipers. I was told this was indicative of cars bound primarily for the US market. Many US cars had right side column shifts for their autos and manuals when column shifters were a thing. I have had a couple with the same position of the auto stick, right of wheel. I actually found it really nice once used to it. It did not help that Maria's Mini had a BMW format auto box so if I went for manual control it was as mentioned above back to front. If you wanted to use the paddles left was (from poor memory) up and right down, where the other car push and pull the paddles. The current Merc E series auto has this stupid little nub instead of a lever, daft. It is definitely an area for improvement if not standardisation in full.
Posts: 5,945 Likes: 28
Posts: 5,945 Likes: 28 |
Yes, our diesel family estate car has, believe it or not, flappy paddles and a sports setting. Wo on Gods earth gets a Merc estate to thrash?
Yes, our diesel family estate car has, believe it or not, flappy paddles and a sports setting. Wo on Gods earth gets a Merc estate to thrash? errrr. Me. S212 E63s estate. Does everything in one car.
Posts: 14,749 Likes: 158
Posts: 14,749 Likes: 158 |
I actually wanted an auto with flappy padles for our new (yet to be delivered) Caddy 😃 , but, a) it was vetoed by  who has never driven an auto, and b) auto is not available with the 4 wheel drive version. What we do get is a 6 speed box with the horrible VW shift pattern. ![[Linked Image]](https://www.vwpolo.net/images/books/1/BTT-0059.png) 6RUL Whoever thought it was a great idea to put reverse next to first? It is too easy, at a quick glance to think it is in first, or in a hurried shift push it into reverse rather than first. The possible result can easily be immagined. The three alternatives of 6RDL, and better still, 6RUR or 6RDR would be much better.
Posts: 6,675 Likes: 441
Posts: 6,675 Likes: 441 |
I have the opposite problem - my Morgan 4/4 Type 9 box is RUL and never had an issue - it's a very positive gear action and you know if it's in or not. However the MGB is a RDL and I'm either trying to put it in a RUL position, or getting 2nd gear.....
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
Our old Series III Land-Rover was RUL and had a very weak spring to prevent accidental engagement of reverse. It caused a couple of thought provoking moments.
Posts: 3,701 Likes: 135
Posts: 3,701 Likes: 135 |
The 5-speed gate on the Ferrari 246 could be intimidating. ![[Linked Image]](https://tm-img.com/images/2025/06/17/Farrari-Gear-Knob.md.jpg) I did once drive a car that my passenger put into reverse while going forwards at 30mph. Fortunately not a Ferrari, but not something I'd want to experience again.
I once read a story about someone driving a Volvo in outback Australia who entered a narrow causeway before realising that a road train was coming towards him at a sustained 60 mph. He managed to get the Volvo into reverse at about 30 mph and shot backwards off the causeway in a cloud of tyre smoke to finish in a ditch.
Posts: 655 Likes: 12
Posts: 655 Likes: 12 |
The 5-speed gate on the Ferrari 246 could be intimidating. The 2CV gear change pattern is even more interesting ![[Linked Image]](https://tm-img.com/images/2025/06/20/A1.jpg) The design memo for the car required a three-speed gearbox. However, Walter Becchia, the engine and gearbox designer, added a fourth gear hidden as an overdrive gear (vitesse de surmultipliée) signified with a S. Harald
Harald +4 4-seater 2008 Squadron Blue
