10 members (vincentvg, RubyMog95, Moggo, John Winn, Hamwich, Jock, simon8201, flyfisher, IcePack, JohnHarris), 142 guests, and 35 robots.
+8Rich 91
John V6 49
Posts837,976
#825457 16/06/25 11:42 AM
JJW Offline OP
Hello,
I am thinking about a rollbar for my roadster. I had the Librands in my plus4 and it was ok. For the roadster I would like a black hoop and maybe a bit higher. I see on the techniques website they do a rollbar suitable for the easy-up with a removable diagonal. Does anyone have experience with this item? Anyone any pictures of it or know how it compares to the Librands system?
Regards JJ
JJW #825475 16/06/25 06:42 PM
Obvious I know, but just make sure the height isn’t compromised by the need for it to fit under the hood.
And of course, unless you have a 4 point harness, then the roll bar becomes purely cosmetic.
Doug
2011 Plus 4 in Rich Maroon
1972 750 “ComDom” sprinter
1958 Triton 650
1992 Triumph Trophy 900
JJW #825491 16/06/25 08:29 PM
I had the Librands roll bar fitted to a previous Morgan, 2004 4/4, so not as tall as a traditional roll bar however it did stiffen the chassis and made a noticeable difference to the handling so wasn’t just a cosmetic change, won’t say improvement as we all have our own views on what our cars should look like.
I also had a 4 point harness fitted which made a surprising difference to my ability, limited as it is, to drive quickly as I was held in place so firmly. Unless you have tried one you don’t realise how much you get thrown about on a bumpy road. Only drawback, other than the extra time to fasten up, was that it was impossible to reach the handbrake!
So I have to say in my experience a roll bar does make a difference.
Andrew
'Alice' 2013 Duratec Plus 4. Pearl Blue
JJW #825503 16/06/25 11:47 PM
Go to Safety Devices, they probably make them for everyone else!
1969 4/4
1995 plus 8
1996 Plus 4 4seater
2002 Aero S1
2013 M3W
2014 Plus 8
Also,I would add, it is not possible to lean forwards to look sidewards at junctions. For a harness to work itmust be done up very tight. Worn loose it is dangerous and worse than useless. I have considered adding a retracting reel to harness shoulder straps. Has anyone done this? Any comments? Or, device was shown on here recently that brings handbrake operation back level with the gear stick.
Another issue with rollbars is that occupant's heads are at risk of hitting the bar while being tossed about during an accident, even while being held in a harness. Driving with a rollbar really requires a helmet.
JJW #825534 17/06/25 06:43 PM
Forgot about that, yes junctions were often a challenge. Plus, just remembered, you have to adjust them when the weather changes as a correctly adjusted belt over a jacket will be too loose if it warms up and you want to ditch the jacket. Knew there was a reason I haven’t repeated this.
Andrew
JJW #825535 17/06/25 07:18 PM
JJW Offline OP
I was looking at 4point harnesses. I came across a 3 point harness from sparco that acts as a 4 point. The shoulder straps are y-shaped and join together behind your back. That would maybe combine nicely with an inertia reel attached to the cross member of the rollbar subframe?
JJW #825536 17/06/25 07:22 PM
jbk Offline
Simmons do a handbrake extender which brings it nearer the gearstick I understand.. Does not solve the stretch to view though
1993 T16 +4 Lancia Blue.
