Posts837,950
Posts: 5,442 Likes: 133
Black Rat Charter Member
Posts: 5,442 Likes: 133 |
Does anybody know where the fuse for the seatbelt warning light is. 2013 Narrow body +4.
Posts: 8,695 Likes: 415
Posts: 8,695 Likes: 415 |
The seat belt buzzer is on fuse 17 10 amp Keith, with all the other devices that trigger it with a switch to ground. Haven't traced it but this fuse is described as also feeding the dash module.
1 member likes this:
xc68anc |
Richard,
All the other waring lights come on upon initial ignition turn on but no seatbelt warning. Everything else works fine.
Posts: 5,594 Likes: 612
Posts: 5,594 Likes: 612 |
Also does the buzzer work when you don't belt up?
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
There's a loom to seat connector tucked under the seat, check it's not come loose or corroded pins
Posts: 2,094 Likes: 75
Posts: 2,094 Likes: 75 |
There's a loom to seat connector tucked under the seat, check it's not come loose or corroded pins Most probable. Search between the driver seat and the transmission tunnel for a small black connector with 2 wires.
Could be the bulb are they changeable ? no buzzer never has been, wires under seat connected can I check them what should I expect ?
Thanks for info on (lack of) buzzer Keith. Last published schematic shows one  Typically the seat belt switch completes a circuit to ground when the belt is not deployed. You can disconnect plug and check for continuity with/without seatbelt. FWIW my Roadster has the delayed "dong" seatbelt audible warning.
UPDATE
I think the bulb has probably gone because the A/C light is not coming on either. I checked the wiring switch in the seatbelt plug is ok this is connected by the side of the seat to the wiring loom, alas one of the wires to the loom had snapped this is in a plastic corrugated protected section that has probably been caught in the seat runner. It would require the seat removing and possibly the transmission tunnel so I will live with it. I would still like to know if the bulbs are interchangeable or are they part of a module ?
