10 members (Mogdavid, JoeSpeetjens, Plus Four Guy, jbk, Jock, RobS, simon8201, IcePack, MartinB60, PaulJ),
293
32
Posts837,973
Posts: 8,692 Likes: 498
Posts: 8,692 Likes: 498 |
Thanks Jon, I did try that without much success. Difficult to do properly in situ, also difficult to set up with a digital meter. I'll have a proper go when I have replaced it and aquired a decent analogue meter. There's an interesting article here REPAIRING_THE_STANDARD_RB106. In particular the addition of a diode to reduce the regulator contact arcing and burning is an interesting mod. Thanks for that article, copy gone in the Mini file
Posts: 2,433 Likes: 17
Posts: 2,433 Likes: 17 |
When I rallied my '64 'S' back in the 70's we used to 'screw' the control box to give a higher charging rate, I was running Quadoptics and 2 Super Oscars ok but you had to be careful in daily use that you didn't boil the battery. Happy memories.....
1969 4/4 1995 plus 8 1996 Plus 4 4seater 2002 Aero S1 2013 M3W 2014 Plus 8
1 member likes this:
CooperMan |
The option of modern LED bulbs has made keeping the old style dynamos in use much less risky
Posts: 472 Likes: 70
Posts: 472 Likes: 70 |
New regulator arrived and fitted. All now working correctly  Haven't fitted a diode as recommended as I haven't got one and since the demise of Maplin not so easy to get just one. Note to anyone else needing to change the regulator. Mine was fixed to the bulkhead using two nuts and bolts. It was a challenge reaching the nuts way under the panel so on refitting I used two M5 rivnuts, so much easier.
1956 Plus 4 4 seater
Posts: 1,030 Likes: 120
Posts: 1,030 Likes: 120 |
