2 members (DickJ, Davetherave),
248
Topics49,918
Posts838,260
Posts: 85 Likes: 18
Posts: 85 Likes: 18 |
Hello
What is the brakes reaction bar? Is the roadster 3.7 have it if the car is stock or not?
Thank you
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
Hello
Thank you This is how my favourite dealer describes them. You can fit them yourself if you wish. Allon White Brake Reaction BarAlso available here Librands Brake Reaction Bar and through most Morgan specialists.
Posts: 8,706 Likes: 416
Posts: 8,706 Likes: 416 |
Hello
Thank you It's a diagonal tubular brace fitted between top of kingpin (secured under its top bolt) down to chassis rail flange as shown below. ![[Linked Image]](https://www.tm-img.com/images/2019/03/27/205839BC-7CB3-4F95-AB33-4A51CC2F5D3B.jpg) Without doubt it should have been a standard factory fit but remained an option until end of Classic production. It does more than just handling brake reaction benefitting shock suspension loads as well.
Posts: 27,855 Likes: 767
Posts: 27,855 Likes: 767 |
The cheapest and best mod you can do.
Posts: 1,246 Likes: 30
Posts: 1,246 Likes: 30 |
Adam12. ![[Linked Image]](https://tm-img.com/images/2025/08/11/IMG_0107.jpeg) Is what you are looking for re my previous post. Those who think streuth what a state. It looks much better now I have cleaned it up. My car is used virtually every day & lives by the sea.
Posts: 171 Likes: 32
Posts: 171 Likes: 32 |
Thank you IcePack. With two fresh greasings under its belt the graunching has reduced considerably, but I will have a look to see if there are abrasion marks behind the springs (also live by the sea and also use almost daily, though I suspect there's less salt in the air in southern Sweden than in your fine town)
Adam 2019 Green +4 "Toad"
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
Investigated why the horn had stopped working. Turned out to be failure of the relay. This component was included in the twin Fiamm set up I installed about 6 years ago. Relay is mounted on the nearside inner wing and is readily accessible. On substituting with a spare relay that I keep in the fusebox, the ‘audible means of approach’ returned to the fold! Suspect this stems from a recent incident with a pothole on the nearside, the violent jar probably upset the switch workings. A pair of replacement relays - less than £4 each – are now on their way  ![[Linked Image]](https://tm-img.com/images/2025/08/14/98b80b5b-5c44-40e5-880c-78a0162c1b44.jpg)
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Installed an offset air intake from Merlin Motorsport to collect cold air arriving via an aluminium plate mounted inside the cowl and extending over the top of the radiator. Will it offer any improvement? Who knows, but it chewed up a good few hours in the man cave.
Chris
3 members like this:
RichardV6, Graham, G4FUJ, John V6 |
Posts: 8,712 Likes: 502
Posts: 8,712 Likes: 502 |
Installed an offset air intake from Merlin Motorsport to collect cold air arriving via an aluminium plate mounted inside the cowl and extending over the top of the radiator. Will it offer any improvement? Who knows, but it chewed up a good few hours in the man cave.  Nice work Chris, I did something very similar to the Roadster a few years ago and since the mod the fan hardly ever comes on - so it certainly keeps engine temps lower
Nice work Chris. If you can get an OBD2 scanner working with your car you should find ambient and MAF sensor provided inlet temp available for display. This will prove how efficient your mod is. Should be within 1°C except perhaps when stationary.
