Posts837,997
Posts: 27,836 Likes: 763
Posts: 27,836 Likes: 763 |
10 years is a good run. Glad the tank is well.
1 member likes this:
+8Rich |
Posts: 37,479 Likes: 988
Posts: 37,479 Likes: 988 |
Gave her a pat from you too.
There was an American down there paying his respects and his uncle owns a Morgan and he was most interested in the Plus 8.
Graham, G4FUJ |
Posts: 1,059 Likes: 156
Posts: 1,059 Likes: 156 |
Installed an offset air intake from Merlin Motorsport to collect cold air arriving via an aluminium plate mounted inside the cowl and extending over the top of the radiator. Will it offer any improvement? Who knows, but it chewed up a good few hours in the man cave.  Hi Chris, This looks great, can you share a link to the air scoop you purchased on the Merlin website? Also, could you confirm the origins of the nice looking pipe you used, is it some sort of flue pipe/liner? Thanks, Dave.
Posts: 8,696 Likes: 498
Posts: 8,696 Likes: 498 |
The black scoop looks very similar to the one I used, Revotech was the brand, bought via Demon Tweeks
Posts: 793 Likes: 144
Posts: 793 Likes: 144 |
Dave
I struggle with putting links on here. The scoop is Merlin stock code ID255-800S. Their description is 255mm x 80mm Rectangle Offset Air Duct. I had to modify it to fit.
The hose is from Amazon. A 2.5m length of what is described as “aluminium flexible pipe alloy air ducting tube heat resistant hose”. Mine is 70mm inside diameter but currently cannot find this. 75mm inside diameter is currently available at £8.60 from the INPAV Store whatever that is and would be better than 70mm I believe.
Hope this helps.
Chris
Chris
2015 Plus 4 Silverlake Blue (2014 3.7 Roadster Crystal Blue) (2012 4/4 Sport Black)
Posts: 3,701 Likes: 135
Posts: 3,701 Likes: 135 |
I struggle with putting links on here. The scoop is Merlin stock code ID255-800S. Their description is 255mm x 80mm Rectangle Offset Air Duct. I had to modify it to fit. Here's the link: https://www.merlinmotorsport.co.uk/p/255mm-x-80mm-rectangle-offset-air-duct-id255-80os(BTW the stock code is ID255-80OS, note the O, not a zero)
Posts: 1,031 Likes: 120
Posts: 1,031 Likes: 120 |
I have the ITG cold air intake system, same as sold through Williams. Now, the theory is good but the reality ... well not quite so good! The air filter box is mounted directly above the exhaust manifold and it gets too hot to touch, so rather than a cool air intake it would in fact make a great cold weather pre-heat system like the old cars from the 70's, 80's and into the early 90's used to pre heat the air and prevent carb icing....!
My basic theory on cold air intakes is due to the velocity of the cold (or cool) air passing through the system, it does not have time to be unduly influenced by any warm or hot components through which it passes. This is why I have not lagged the inlet pipe or air filter box.
Granted, the filter element will act as a flow restrictor but to what extent I know not.
Chris
RichardV6 |
Posts: 2,274 Likes: 41
Posts: 2,274 Likes: 41 |
Craig Jezz
Luddite |
Posts: 5,460 Likes: 475
Posts: 5,460 Likes: 475 |
Very smart engine bay Craig, thanks for posting your pics....
