1 members (flyfisher), 307 guests, and 43 robots.
+8Rich 101
John V6 63
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,213
Georgetoad, woolfie
Page 144 of 165 1 2 142 143 144 145 146 164 165
This is my cold air intake...
1 member likes this: Luddite
A sight for sore eyes - harmony thumbs
Originally Posted by Themorganeer
Dave
I struggle with putting links on here. The scoop is Merlin stock code ID255-800S. Their description is 255mm x 80mm Rectangle Offset Air Duct. I had to modify it to fit.
The hose is from Amazon. A 2.5m length of what is described as “aluminium flexible pipe alloy air ducting tube heat resistant hose”. Mine is 70mm inside diameter but currently cannot find this. 75mm inside diameter is currently available at £8.60 from the INPAV Store whatever that is and would be better than 70mm I believe.
Hope this helps.
Chris
Thanks Chris, it's a lovely job thumbs
I need to replicate!
Stupidly I raised the back of my Plus Four's hood without unlocking one of the side Tenax fasteners which duly sheared just below the bodywork!!! Having gotten a replacement in the local yacht chandlers which has two Screws -one either side of the stud, I fitted it, which sorts the problem --Yes-- I did buy 2 fittings as I'm sure I'll do it to the other side sometime in the future too!!!---DOH!!
Robbie
2021 Plus Four -- Helga
211-WX-1433
I know what you mean, btw there are also stainless steel Tenaxes made in Germany, I think more resistant than the brass-chromed!
Ruut Bianchi
Ruut Bianchi
1 member likes this: +8Rich
Black Rat
Black Rat
I never do mine up.
Keith
2013 narrow bodied + 4 Ruby.
Last week an issue with the rear brakes binding finally reached the top of the job pile.
On raising the rear wheels off the ground and slackening the handbrake adjuster, which was almost at the end of its travel, the binding significantly reduced thus confirming the handbrake adjustment was amiss. By taking the adjuster nut in the cradle right to the end of the threadbar, both wheels rotated freely.
Being not particularly happy with this arrangement, it was decided to extend the cable adjuster threadbar. The thread was carefully measured by pressing a piece of paper against it to form an imprint and found to be 1/4" BSF 26. Fleabay was duly raided for a stainless threadbar connector (couldn't find a hex profile at this thread so made do with a cylinder), a short length of threadbar and a pair of hex nuts.
The scary part of this task was the necessity to cut insitu the existing cable adjuster threadbar to a length of about 10mm. Enter a 115mm thin cutting disk and suitable thick cardboard protection. The short stub thread was cleaned up with a thread die and the stainless connector screwed down with threadlock. The new threadbar with a pair of locknuts was inserted into the adjuster cradle and tensioned using one of the original locknuts.
The protruding thread inside the cradle was then protected with a length of plastic tube.
No more brake binding and lots of adjustment available on the threadbar. Handbrake works just fine. Job done.
Adjuster nut right at end of original threadbar.
Replacement threadbar prior to plastic tube fitment.
Chris
2015 Plus 4 Silverlake Blue
(2012 4/4 Sport Black)
Well done Chris
Nice work Chris. You'll soon be doing this work and similar sitting down under car wink
