8 members (B3MOG, John V6, flyfisher, Lordofthewings, Ruut Bianchi, BLUE+4, GrumpyPa, Happy super 3),
321
Topics49,918
Posts838,258
Posts: 1,118 Likes: 17
Posts: 1,118 Likes: 17 |
Was thinking that one could use the plug to start with.. it would come off the garage supply so expect 30 amp load.
Posts: 8,712 Likes: 502
Posts: 8,712 Likes: 502 |
Was thinking that one could use the plug to start with.. it would come off the garage supply so expect 30 amp load. You can, just need to restrict the charge rate in the vehicle menu to say 13 amps (around 3kW) for safety, and if you have one use an RCD (earth leakage) protected circuit / socket or adaptor
Posts: 1,815 Likes: 32
Posts: 1,815 Likes: 32 |
Octopus allow it but only with one specific charge point & certain BEVs. The link is hereHilarious - only works with a no-longer-available charger and 3 cars - 1 a PHEV, and 2 Nissans! What you might call “exclusive”
Posts: 12,269 Likes: 324
Posts: 12,269 Likes: 324 |
Octopus allow it but only with one specific charge point & certain BEVs. The link is hereHilarious - only works with a no-longer-available charger and 3 cars - 1 a PHEV, and 2 Nissans! What you might call “exclusive”  A common business problem. You can kill your company by failing to bring new products to market quickly enough. And you can kill your company by rushing to market with a poorly developed immature product. In a fast-changing situation like EV technology this must be a nightmare to get right.
Posts: 5,469 Likes: 172
Posts: 5,469 Likes: 172 |
This is why so many innovative products fail to achieve a market presence.
For those who are interested, Geoffrey Moore's book "Crossing the Chasm" is still relevant.
Posts: 1,038 Likes: 36
Posts: 1,038 Likes: 36 |
Was thinking that one could use the plug to start with.. it would come off the garage supply so expect 30 amp load. I'm charging with a 3 pin plug, waiting for my charger installation on the 10th of this month. Managing well so far but I plug in as soon as I get home. In the unlikely event that you ran the battery right down I'd think it would take a couple of days to charge fully on a 3 pin supply. Next step, for me, is to decide which of the Octopus EV tariffs to choose.
Posts: 27,855 Likes: 767
Posts: 27,855 Likes: 767 |
I use Octopus Intelligent Go but then you need to spend c £1k on a charge point. I calculated that had an 18 month payback.
I tend to run the car down to between 20 & 40% so that the charge needed is large and then IGO decides to charge outside the 23:30 to 05:30 at the same tariif and thus I get 7p / unit electricity during a part of the day.
I also have pv panels & batteries. I charge the batteries at the 7p rate and on sunny weeks like this one I export power at 15p / unit.
So it arrives next week 5th November... think I have settled on the charger a Simpson and Partners Home v3 with Intelligent Go. Not sure on tethered or in tethered..
Posts: 2,096 Likes: 260
The TM in Talk Morgan Talk Morgan Expert
Posts: 2,096 Likes: 260 |
So it arrives next week 5th November... think I have settled on the charger a Simpson and Partners Home v3 with Intelligent Go. Not sure on tethered or in tethered.. Have you looked at Andersen chargers? https://andersen-ev.com/Also, worth looking at Octopus, they are doing a flat price of £30 per month, to charge your EV as much as you want within the given month. Or 5,000 free miles with certain Andersen chargers.
Hi Simon, Yes I have it’s a though call between the S&P and Anderson Quartz. But the R5 is due to be Car to Home / Grid comparable next year and the S&P can be upgraded for this but the Anderson can’t. The 5000 mile offer is good takes £105 off the price but think you need to do 30k miles a year for the anytime to work out better and also want to use the off peak for the house electric Many thanks Will
