8 members (B3MOG, John V6, flyfisher, Lordofthewings, Ruut Bianchi, BLUE+4, GrumpyPa, Happy super 3), 321 guests, and 25 robots.
+8Rich 101
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,258
Smed., Spanner Juggler
Page 2 of 6 1 2 3 4 5 6
OP Online Content
Ordered it, a entry level 40kw one in Black, would of gone for Pop Green myself but need to keep everyone happy..
Hopefully gets ordered before work closes the scheme, realistically likely delivery n September was quoted 16 weeks
Just need to get a smart meeting and charging point fitted once order is in build..
It’s crazy the cost of the charging point… hopefully prices might come down.
TIA
Will
Well done. I look forward to your thoughts once it arrives.
Originally Posted by John V6
Octopus allow it but only with one specific charge point & certain BEVs. The link is here
Considering how many EV's are available nowadays, a choice of 3 isn't very inspiring Octopus
TIA
Will
Will, I was lucky and got a BMW subsidised one at our previous house
Have a search for local Sparkies that have approval to install charge points, they can be way more competitive than the so called 'specialists'
mph Offline
TIA
Will
You can still get a government subsidy of £350 towards the cost of your charging point. The only catch being that you need to own an EV before you can get the grant.
Octopus charging point including installation starts at around £900, with the government subsidy it comes down to £550 which I don't think is too bad.
You may find someone local to do it a few pounds cheaper but personally I didn't think it was worth it.
But the grant isn't for everyone.
In England, the Electric Vehicle (EV) Chargepoint grant can help reduce the cost of installing an EV charger at home. This grant is available for both landlords of residential and commercial properties, as well as renters and flat owners. It provides up to 75% of the cost of buying and installing an EV chargepoint socket, capped at £350 per socket.
mph Offline
I didn't realise that.
So the grant isn't available for a house owner with on drive parking?
It seems odd it's just for flats...
OP Online Content
Going to wait and see on charger point as expect it will be a while to get delivered, maybe come August / September there will be a better deal on them
Yes Octopus certainly seem to have active marketing campaigns from time to time. You may also find if you do only low mileage that the granny charger works for you at 2 kW/hr & you can still use an EV rate like Octopus Go. But check the supply cable in your house & any extensions can handle the load.
