1 members (Johnnyboy),
200
Topics49,918
Posts838,255
Posts: 2,050 Likes: 12
Sir S1'a'lot Talk Morgan Expert
Posts: 2,050 Likes: 12 |
I’ve an idea I might have mentioned this before.
Drivers side, I Cannot get the wiper to clear. I knew the screen was distorted and thought that the reason but a HUGE expense I fitted a new screen. New wipers at least twice as I’d forgotten I’d already changed them BUT to no avail.
Anyone experiencing the same??
2002 Aero 8 S1 2023 Plus 4 (woman’s)
Posts: 7,936 Likes: 133
Posts: 7,936 Likes: 133 |
Have you tried bending the arm to alter the angle at which the blade contacts the window and/or the pressure at which the blade meets with the glass?
I seem to recall this was the issue on my S3 and that was how MMC resolved it; however, I’ll do a bit of digging and come back to you on it.
Posts: 8,706 Likes: 416
Posts: 8,706 Likes: 416 |
Try changing the sprung arm (stronger spring) in addition to wiper blades. Simon's suggestion can also increase effective spring force on blades but also distributes balance of this force to favour one end of blade or the other.
Posts: 11,536 Likes: 321
Posts: 11,536 Likes: 321 |
The springs often become weak leading to poor wiping. If they are juddery then it can be a sign of the mechanism needing tightening.
Had a chat with Mr Aero today and my recollection is correct, as are Richard and Alistair's comments.
A mild 'adjustment' of the arm is generally the solution on newer cars; however, as your car is now older, perhaps go for replacing the spring first and then look at the arms. I believe, although I may be mistaken, that some Morgan parts companies actually sell upgraded springs - so this may be worth a look.
Posts: 5,473 Likes: 476
Posts: 5,473 Likes: 476 |
apologies for heading off at a tangent but this is TM is it not..?
Way back in the mists of time I had a similar issue on my Mini....! It does seem others suffered it too, and to the extent that an accessory company created a set of white plastic aerofoils which could be clipped on to the wiper arms and supposedly added a degree of extra pressure betwixt wiper blade and screen....I think the suggestion was that they cancelled out the effect of reducing pressure on the wiper rubbers as ones speed increased, for those of us who were really fast drivers, they were a must have.....(-:
Posts: 8,712 Likes: 502
Posts: 8,712 Likes: 502 |
Viper, suggest you have a chat with Peter at mog67.pg@gmail.com who nicked further developed my idea and doesn't pay me commission
Posts: 2,096 Likes: 260
The TM in Talk Morgan Talk Morgan Expert
Posts: 2,096 Likes: 260 |
Way back in the mists of time I had a similar issue on my Mini....! It does seem others suffered it too, and to the extent that an accessory company created a set of white plastic aerofoils which could be clipped on to the wiper arms and supposedly added a degree of extra pressure betwixt wiper blade and screen....I think the suggestion was that they cancelled out the effect of reducing pressure on the wiper rubbers as ones speed increased, for those of us who were really fast drivers, they were a must have.....(-: Bosch Super Plus wiper blades have little spoilers on them, which are designed to have the same effect. I would imagine the strange Morgan size will mean they don't offer them in the format for the Aero, or any other Morgan; however, I believe the principal is the one you are describing, George
Simon, thanks for taking the time to acknowledge that my thinking on wiper aerofoils is not entirely flawed....
Simon, thanks for taking the time to acknowledge that my thinking on wiper aerofoils is not entirely flawed....  Your memory is correct they were de rigueur for all the Mini & Escort lads in the 70's Modern copies are available https://www.ebay.co.uk/itm/395349970282
1 member likes this:
Luddite |
