Morgan Aero 8
5 members (John Winn, JohnHarris, DalesPlusFour, BHV, Mike D), 234 guests, and 34 robots.
+8Rich 102
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,256
Smed., Spanner Juggler
#837533 27/01/26 10:49 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
I’ve an idea I might have mentioned this before.
Drivers side, I Cannot get the wiper to clear. I knew the screen was distorted and thought that the reason but a HUGE expense I fitted a new screen. New wipers at least twice as I’d forgotten I’d already changed them BUT to no avail.
Anyone experiencing the same??
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Viper #837534 28/01/26 07:31 AM
Have you tried bending the arm to alter the angle at which the blade contacts the window and/or the pressure at which the blade meets with the glass?
I seem to recall this was the issue on my S3 and that was how MMC resolved it; however, I’ll do a bit of digging and come back to you on it.
Viper #837535 28/01/26 07:59 AM
Try changing the sprung arm (stronger spring) in addition to wiper blades. Simon's suggestion can also increase effective spring force on blades but also distributes balance of this force to favour one end of blade or the other.
Viper #837541 28/01/26 10:49 AM
Smile, it confuses them
The springs often become weak leading to poor wiping.
If they are juddery then it can be a sign of the mechanism needing tightening.
Viper #837548 28/01/26 02:50 PM
Had a chat with Mr Aero today and my recollection is correct, as are Richard and Alistair's comments.
A mild 'adjustment' of the arm is generally the solution on newer cars; however, as your car is now older, perhaps go for replacing the spring first and then look at the arms. I believe, although I may be mistaken, that some Morgan parts companies actually sell upgraded springs - so this may be worth a look.
Viper #837568 29/01/26 12:10 PM
apologies for heading off at a tangent but this is TM is it not..?
Way back in the mists of time I had a similar issue on my Mini....! It does seem others suffered it too, and to the extent that an accessory company created a set of white plastic aerofoils which could be clipped on to the wiper arms and supposedly added a degree of extra pressure betwixt wiper blade and screen....I think the suggestion was that they cancelled out the effect of reducing pressure on the wiper rubbers as ones speed increased, for those of us who were really fast drivers, they were a must have.....(-:
Viper #837590 29/01/26 07:24 PM
Viper, suggest you have a chat with Peter at mog67.pg@gmail.com who nicked further developed my idea and doesn't pay me commission laugh2
Luddite #837616 30/01/26 11:43 AM
The TM in Talk Morgan
Bosch Super Plus wiper blades have little spoilers on them, which are designed to have the same effect. I would imagine the strange Morgan size will mean they don't offer them in the format for the Aero, or any other Morgan; however, I believe the principal is the one you are describing, George cheers
Viper #837621 30/01/26 02:22 PM
Simon, thanks for taking the time to acknowledge that my thinking on wiper aerofoils is not entirely flawed.... thumbs
Luddite #837634 30/01/26 06:28 PM
Your memory is correct they were de rigueur for all the Mini & Escort lads in the 70's
Modern copies are available https://www.ebay.co.uk/itm/395349970282
1 member likes this: Luddite
