Morgan Aero 8
1 members (Carbuilder), 226 guests, and 22 robots.
+8Rich 104
John V6 65
Suspension upgrades
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
First Morgan as it is now
by Strathaven, September 15
Topics49,918
Posts838,254
Smed., Spanner Juggler
Originally Posted by Luddite
Simon, thanks for taking the time to acknowledge that my thinking on wiper aerofoils is not entirely flawed.... thumbs
Your memory is correct they were de rigueur for all the Mini & Escort lads in the 70's
Modern copies are available https://www.ebay.co.uk/itm/395349970282
I believe you get a discount if you order them alongside the sellers other item for sale: custom vinyl name decals that go across the top of the windscreen, proclaiming the name of the driver and that of his lady passenger! grin2
I must admit to having a chuckle when I see drivers with their instagram handle stuck to their side windows, letting all know the link to their social media profile; however, then I ponder some of the questionable 'mods' we did to our cars in our youth and think, well, the circle just goes on!
Viper #837697 31/01/26 09:21 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Thank You Ladies and Gentlemen.
The wipers are brand new, I discovered I had two brand new set, neither work.
They do have the severe bend in the wiper arm to create extra pressure.
The springs are obviously good.
Aerofoil may work at speed of course, not a bad idea. I have an old escort which I might nick it off wink
But it won’t help at low speed which sadly seems to be the norm on our congested roads.
Not had this issue on either of my 2 previous S1’s. All a bit odd
2002 Aero 8 S1
2023 Plus 4 (woman’s)
Viper #837714 01/02/26 10:33 AM
Is it worth buying a new arm and spring, just to check. I remember messing around for ages (as in weeks of trial and error) trying to get mine just right on the S3 and even then it was the factory who sorted it. Perhaps they are over/under bent but starting with a 'blank' canvas may help.
Viper #837740 01/02/26 03:37 PM
Had another thought, seem to remember a product that seemingly dispersed rain reducing the requirement to use the wipers to some degree, think it was called Rain X or similar, which might help out a tad.. Also if using just water in the washers perhaps try buying windscreen washer fluid which I suspect has a degreaser built in to assist in cutting down the oil that inevitably ends up on the screen. Also if that may not appeal, and oil/crud might be part of the issue, either vinegar or Fairy liquid might be worthwhile trying..?
Simon #837748 01/02/26 04:54 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Simon. I’ve effectively done that. I have two sets of new jobbies.
2002 Aero 8 S1
Luddite #837750 01/02/26 04:57 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Yes, I’ve also done this. Not great on a fairly upright screen. But it’s more an issues when there’s dirt that needs washing away
2002 Aero 8 S1
Viper #837920 04/02/26 10:32 AM
Last attempt.... Had a wander around and came across an aerofoil that fitted to the back of a wiper to add to the pressure upon the blade but it was in the US, so discarded that idea... Then found these with a broader backing to the blade which might just help a bit... ?
https://www.ebay.co.uk/itm/187403024139?mkevt=1&mkcid=1&mkrid=710-53481-19255-0&campid=5339129536&toolid=20006&_trkparms=ispr%3D1&amdata=enc%3A1kZkdhBHeQ8Cc2Pywt9duNg24&customid=e3a401fa8e321e246457687993e09944&loc_physical_ms=41949&loc_interest_ms=&msclkid=e3a401fa8e321e246457687993e09944
If the link does not work you could try ebay search for
Windscreen Wiper Spoiler Front Blade Bloom M10 300mm / 12'' with 10 adapters Car
https://www.ebay.co.uk/str/carmaxaccs?_trksid=p4429486.m168239.l149267
Viper #838018 05/02/26 03:14 PM
Viper Offline OP
Sir S1'a'lot
Sir S1'a'lot
Thank you Luddite. I’ll give it a go.
2002 Aero 8 S1
Viper #838025 05/02/26 05:19 PM
I was watching a couple of vids that involved footage from inside a couple of 250 GTO`s a day or so ago, and the wipers were fluttering a tad, which caused me to wonder just what it must have been like to drive these cars in races in the rain and more so the 24 hr races which both cars had a history so related... All that aside I do hope the wider wiper backs improve things at least a bit for you Viper.. thumbs
Viper #838036 05/02/26 07:30 PM
Mr Luddite mentioned it earlier but I'm a fan of RainX, you hardly need the wipers on for light rain as the water just beads and skates off the 'screen as you drive, it also seems to lube the glass helping the wipers to sweep without jumping
