5 members (R1NGA, Bishmog, How, CRL, B&C Morgan), 240 guests, and 36 robots.
+8Rich 94
John V6 50
Posts837,997
rockabilly john
Originally Posted by Massi_torino
need to remap ECU if I fit the MEX 1105 standard ?
No remap required Massi_torino.
Dave.
Originally Posted by sewin
Hey you don't think I'm going deaf in my old age do you Dave?
You should try Monty!
As anything over 4,400rpm my custom long runner exhaust manifold, sports cat and half size straight through silencer box will make your ears bleed
listening
My very teenager 'Pops & Bangs' map also enhances the aural experience on the overun, I very much doubt there's anything left of the sports cat after it saw a few sessions at Prescott and Castle Combe innocent
The gunpowder smell is wonderful cloud9
The Fusion Fabrications inlet completes my very childish work laugh2
Black Rat
Black Rat
I have the sport silencer but not the full sport exhaust, just about right.
Keith
2013 narrow bodied + 4 Ruby.
Good afternoon,
So, the P.N. on the silencer is AER 4500. The peculiarity is that it's welded to the pipe that extends all the way to the rear, as well as the front, so the 1105 suggested to Dave can't simply be swapped out without extensive modifications or even replacing the pipes. Strange but true. This type of silencer was installed at the factory.
Suggestions?
Good afternoon,
Suggestions?
I suggest visiting a good exhaust fabricator local to you, explain your objectives and let the fabricator build you an exhaust system to suit your requirements.
Dave.
All very good suggestions, I personally would insulate you rear deck first, wont cost very much or take very long and if it improves the ambience in your cabin.....job done.
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
Good afternoon,
Suggestions?
That's interesting. The factory side exit Sports exhaust for 3.7 Roadster also have the tail diffusers welded to the silencer back plate. In this case the pipe is so short as to be irrelevant.
Note the Plus 4 used the same silencer MEX1105 as 3.7 Roadster. This means the separate rear pipe and tail diffuser will fit your Plus 4 as well, confirmed by part number. I have these latter parts (MEX1184) surplus plus hanger, after fitting above sports pipes. PM if interested as all you will then need to convert to standard quieter factory system is an MEX1105 silencer - unfortunately I sold both of mine.
Hi Dave, so the silencer you mentioned on eBay seems to be the right one. I tried to buy it, but unfortunately the seller only enabled UK sales. I contacted him through eBay and he says he can't change the shipping settings. I'm sorry because the price was very good. He suggested I have it purchased from a friend in the UK, but unfortunately, since I don't know anyone in the UK, I'll have to pass.
They asked me €580 to build one.
by max
A bit of a silly question and sorry for any thread drift, but how do I tell if my 2019 Plus 4 110 edition has the "sports" exhaust? Does it look different from the standard exhaust?
Adam
2019 Green +4 "Toad"
No Adam, You need to find the minute plate welded to the outer end of the box, it's usually on the top surface. it will either have MEX1105 0r MEX1107. I'm not being funny but there really isn't that much difference between them sound wise. If you want a really sporty sounding exhaust then I'd suggest a librands sport exhaust from the cat back with or without a side exit pipe. At a point in time around the introduction of the Gdi engine the 1107 was the standard fitment.
