2 members (DavidR, M3WMW), 200 guests, and 33 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,149
Georgetoad, woolfie
#84558 08/03/12 08:25 PM
V
V
I was having a wonderful drive today in bright sunlight, until I turned due east into the sun and without a sun visor was not good.
Have anyone fitted the Sun Visors you can buy which say they can be clipped to the top of the windscreen.
Are they easy to fit and how successful ?
Thanks
___________________
4/4 sport 2009
I've got them on my MOG, they literally just clip over the top of the screen. Most of the time they are useless as sun visors unless the sun is very low in the sky because the screen is so low.
One thing I did discover was that with the hood up there's a very small gap between the screen and the hood rail and in heavy rain at speed I got unite wet. Must remember to unclip the visors before I put the hood up.
Steve L.
1996 Plus 8
N22 MOG
If you have the 4/4 Sport with the 9 stud screen you more than likely have the mounting bosses for the sun visors on the inside. That means you won't get the water leaks..........well not as a result of the visors anyway!
Where did you get them? I guess they also work as a deflector wen not used as a sun visor.
Keith
I have the factory fitted vizors - as N22 MOG says, they are fairly useless against the sun and I find a baseball cap more effective
Pete
petemog #84593 09/03/12 07:38 AM
Buy a baseball cap
John V6 #84596 09/03/12 07:57 AM
thumbs
4/4 sport
John V6 #84611 09/03/12 08:31 AM
That's my answer too! smile
Cheers,
Posting Desperado
Posting Desperado
Come up the frozen North and you wont have that problem . The lads are correct a large peak on your base ball cap does the trick . sunny
I bought them from Allon White, I got green tint (because my Mog's greeen) but I think they also did grey/brown and blue. Agree with the baseball cap solution for the sun, and I'm follicley challenged so it protects me from sunburn at the same time.
Steve L.
1996 Plus 8
N22 MOG
