1 members (JoeSpeetjens),
265
32
Topics49,911
Posts838,148
Posts: 41 |
I was having a wonderful drive today in bright sunlight, until I turned due east into the sun and without a sun visor was not good. Have anyone fitted the Sun Visors you can buy which say they can be clipped to the top of the windscreen. Are they easy to fit and how successful ?
Thanks ___________________ 4/4 sport 2009
Posts: 1,569 Likes: 12
Posts: 1,569 Likes: 12 |
I've got them on my MOG, they literally just clip over the top of the screen. Most of the time they are useless as sun visors unless the sun is very low in the sky because the screen is so low. One thing I did discover was that with the hood up there's a very small gap between the screen and the hood rail and in heavy rain at speed I got unite wet. Must remember to unclip the visors before I put the hood up.
Steve L.
1996 Plus 8 N22 MOG
Posts: 14,009 |
If you have the 4/4 Sport with the 9 stud screen you more than likely have the mounting bosses for the sun visors on the inside. That means you won't get the water leaks..........well not as a result of the visors anyway!
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
I've got them on my MOG, they literally just clip over the top of the screen. Where did you get them? I guess they also work as a deflector wen not used as a sun visor.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
Posts: 526 |
I have the factory fitted vizors - as N22 MOG says, they are fairly useless against the sun and I find a baseball cap more effective
Pete
Posts: 27,846 Likes: 765
Posts: 27,846 Likes: 765 |
Posts: 81 |
4/4 sport
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
That's my answer too!  Cheers,
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
Come up the frozen North and you wont have that problem . The lads are correct a large peak on your base ball cap does the trick .
I've got them on my MOG, they literally just clip over the top of the screen. Where did you get them? I guess they also work as a deflector wen not used as a sun visor. I bought them from Allon White, I got green tint (because my Mog's greeen) but I think they also did grey/brown and blue. Agree with the baseball cap solution for the sun, and I'm follicley challenged so it protects me from sunburn at the same time.
Steve L.
1996 Plus 8 N22 MOG
