0 members (), 161 guests, and 77 robots.
+8Rich 62
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,761
Biggle Offline OP
Can anyone with the First version of the G56 Carbon Front Mudguards show/explain what they did to the metal brackets to reduce the carbon wobble?
JMD Offline
Hi
What is wobbling?
There were different variants of the brackets to fit the different steering arm variants (height on hub depending on variant for comfort kit) in some of the earlier cars.
Have you checked with Chris Horton (@G56) that you have the right brackets for your car especially if you have got one of the used Mk1 G56 mudguards that are around?
We have the Mk1 guards and they are fine but we got them from Chris years ago and discussed what brackets we needed for our early 2012 car.
Where are you located?
Biggle Offline OP
Hi,
I too have an early 2012 car (chassis 004) You sound like just the expert I need! I therefore really, really appreciate any guidance you can give me.
To start with, I purchased the "used" Mk1 off Chris himself under the Gentlemans agreement that the bracket situation will be problematic and I will therefore need to sort that out myself!
That said it did come with brackets and I have guessed how they fit with the pre-existing holes... I can find no examples on the internet of other bracket setups.
Here is how it I have currently configured it together on my M3W.... https://photos.app.goo.gl/wVxwRLu5gGjBzXLz5
The good....... The three main bolts holding it to the hub + the top bar + attached "L" bracket all seem rock solid
The bad.... The lower long triangle bracket (at the very bottom of the mudguard) wobbles quite a lot (at it lowest point where the single bolt is) . This cause the whole curve of the main mudguard to wobble along its length, even at slow speeds. Currently the wobble is that bad that its almost as if its made out of cardboard, not CF!
I just like to re-iterate that I entered into buying these Mk1's in full knowledge that i may have some cocking around to do, so this is no reflection on Chris (who i could have brought a far more expensive set of Mk2 instead!)
JMD Offline
Ours is rather differently arranged...if you PM me your email, I'll send you a picture.
Biggle Offline OP
PM'ed you my email... Seeing that photo would be really helpful, looking forward to having a tinker at the weekend.
Biggle Offline OP
Just for completeness (and for anyone else with the issue). I had installed the brackets upside down. Once corrected wobble is almost completely gone.
Here is a photo of how it is supposed to look. https://photos.app.goo.gl/KDGUrMKjzvzNBHZN7
