1 members (Taffmog),
283
58
Topics49,918
Posts838,254
Posts: 52 Likes: 7
Posts: 52 Likes: 7 |
It was no surprise to find the rattling or clunking from the bonnet on my Plus 4 but on inspection I found that the position of bonnet rubber meant it was not anywhere near the surface of each side when closed. My solution was to get two additional rubbers and a pair of plastic spacers from a wall mounted TV kit and reassemble these so that each rubber was mated to its partner and a spacer allowed me ensure that the combination actually allowed each bonnet side to rest securely once it was closed by the latches on each side.
Next step was to grease the flat strips at front and rear and add a few neoprene drawer bumpers from kitchen DIY. Definitely a big improvement.
Robin
2005 Plus 4 1976 Plus 8 prev 1972 4/4 prev 1959 Series 2 prev
Posts: 8,706 Likes: 416
Posts: 8,706 Likes: 416 |
I put candle wax on my bonnet support strips. Grease attracts muck and leaves an awful mess. Remember the fixed bonnet catches have slots to allow up and down movement, in turn offering bonnet seating adjustment.
1 member likes this:
gomog |
Posts: 2,096 Likes: 75
Posts: 2,096 Likes: 75 |
I added some clip-on foam rubber car door seal along the length of the under- bonnet strips that run parallel to the hinges. Doesn’t impede bonnet closing but stops the rattles.
Posts: 5,473 Likes: 476
Posts: 5,473 Likes: 476 |
Parts rattling on a Morgan....! If the rattle stops, then I suspect the part has fallen off...? (-:
Posts: 28,915 Likes: 354
Posts: 28,915 Likes: 354 |
 Same is said for original Land Rover / Defender
