4 members (CBY, Topline123, Sheridan, Graham, G4FUJ), 218 guests, and 76 robots.
+8Rich 64
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,880
Posts837,776
#849180 05/09/26 01:58 AM
moggin Offline OP
My 2025 Plus Four dashboard gauge oil level reading always reads 4/4 even after recent dealer oil change. I've heard that it should read 5/4 when full. Is this so? And how much oil should I add to read 5/4 without overfilling it? Thanks.
You can't beat a man at his own game.
Page 33 of the Plus Four 2025 handbook (found here: https://morgan-motor.com/wp-content/uploads/Plus-Four-Handbook-V1.1-MY25-Web.pdf) which is titled "DRIVER INFORMATION PANEL Oil Level Readings" shows that an oil reading of 4/4 (green coloured oil can and engine bay symbols) indicates "4/4: Engine oil is full." The handbook also indicates the volume of oil that would need to be added if the reading shows the oil level is low, 3/4, 2/4, 1/4 etc. with amber or red coloured engine bay symbol. Addition of more oil when the test indicates a 4/4 status would eventually lead to "!" red symbol and "OVERFILL: Engine oil has been overfilled. Do not drive." Not to a 5/4 status. Whoever told you it should be 5/4 needs to be corrected. Your readings indicate that the dealer has refilled with the correct volume during the oil-change.
I think it is 250 ml per unit eg 3 to 4 . I was told 5/4 wasn't a problem.
Every time we go on a long trip, my wife asks if I have checked the cars oil. I reply I’m the only dipstick it has but she always asks . Thinks she just likes me calling myself a dipstick !? Could be worse. I know I’m the oily rag to her organising brain; she knows everything which is why I sold our set of The Encyclopaedia Brittanica .
Have a good weekend . MM
Our 2020 PlusSix has always shown 5/4 when full, questioned 2 main dealers about it and they both said its fine.
Maybe the earlier CX cars show 5/4 full and Morgan fixed this later in MY builds to show 4/4 in later cars.. its the sort of thing they would do??.its just a guess..
Dave
Plus Six "Squeak"
Roadster departed.
No apparently it is a BMW thing I'm told
1 member likes this: Plus Four Guy
Mine is always 4/4, even after a service at MMC.
Plus Six "Rachel"
Volvo C40
2020 car 5 4 on full also.
intriguing. Somewhat like Spinal Tap.
My handbook (MY23) says that 4/4 is "full", 3/4 needs 250ml, 2/4 needs 500ml, 1/4 needs 750ml, therefore implying that 0/4 needs 1000ml.
On the working assumption that the oil capacity of the car is significantly more than 1000ml, the display would appear to be like a digital dipstick, which has minimum and maximum lines on it. Anywhere between the two - I assume - is OK. It could be bad news to drop below the minimum line (0/4), equally it might be bad news to go above the maximum line (4/4).
On a physical dipstick I tried to keep between the min and max lines, never going too close to the minimum and never going too close to the maximum. If it's your habit to fill above the maximum line on a physical dipstick (i.e. 5/4) then you may wish to try it, but in the absence of any further information I don't think it's a good idea.
Plus Six "Rachel"
Volvo C40
