The most prudent game plan would be to 1. check what relay your Plus 8 has and 2. whether it still functions, then 3. the fan fuse and what its amperage is , 4. the fusebox integrity and 5. then take your engine compression. L
It turns out the 30A fuse has indeed blown as well. That fuse sits by itself in the front engine bay. The power cables leading to the fan are also scorched. .
Hi again riri,
It is as expected..and happily only melted/fused solid from the fuse and relay to the fan. They protected the fusebox and wiring from it. Sad nonetheless. I use a 40amp fuse with a SPAL 40 amp relay and along with their wiring. Your fusebox fuse merely covers the relay "trigger" for the SPAL relay. I can't figure why the fuse/relay didn't blow rather than fusing and melting the fan! We shall be more prudent with what you buy now. Stick with SPAL ancillaries rather than another setup. I have never had a SPAL system give me a problem on any Plus 8.
I gather you have not checked the engine compression yet. That can be done without starting the engine. It is your biggest worry. Unlikely, but it must be checked. You can do that yourself...even with an inexpensive pressure tester.
https://www.gomog.com/allmorgan21.html#ENGINE. BTW, was the rear of the radiator core damaged from the heat?
And yes, engineering and experience should always set your priorities.
1[b]. the new fan should, ideally, fit the brackets you have.
2. have a depth or a smaller one that fits the space you have. You can use tape measure with the rad in the car or measure the depth of the fan once removed.
3. produce the most CFM (cubic feet of airflow) (aka M3/hours) you can find.
I have picked a coup,e of possibilities out. The example posted is rather low cfm, IMHO. For example, my 12 inch SPALs pull well over 2300 cfm. Determine the part # of the melted one in the car. Then you can choose with wisdom and availability near you. I always take issues as an opportunity to improve Morgans.
Lorne
