5 members (sprinty, +8Rich, JohnHarris, Saxonian, Gonze), 246 guests, and 25 robots.
Luddite 54
Topics49,904
Posts838,095
Page 22 of 22 1 2 20 21 22
Is it possible to fashion a similar catch adaption for the forward catch to lift it enough to clear, but secure enough to hold the bonnet securely, rather than the expense of the scoop. Failing that Steve at VSM may be able to help
https://www.talkmorgan.com/ubbthreads.php/galleries/633738/new-bonnet-scoop This is a nicely executed scoop I think nicer than the standard Morgan scoop.
I asked AI what using the new manifold configuration would be the likely impact
With your 2.0L Duratec engine already highly modified—sporting a Stage 3 cylinder head, open exhaust, and pushing an impressive 180+ bhp—your engine is severely bottlenecked by its current intake configuration (presumably the stock Ford plastic dual-runner manifold or a mild variant).If you swap the stock intake system for the Fab9 Elite Intake Manifold combined with an appropriately matched larger throttle body (such as a Bosch 68mm unit) and a proper ECU remap, you can realistically expect a power improvement of 12 to 18 bhp at the flywheel.
[1] (https://www.reddit.com/r/MiataNC/comments/1kodmfc/finally_installed_the_fab9_elite_intake_manifold/
)Because your engine already has a high-flowing Stage 3 head, it is starved for air at higher RPMs. The Fab9 manifold will directly unlock that hidden capacity, likely pushing your total output right to the 192–198 bhp threshold. [1] (https://www.reddit.com/r/MiataNC/comments/1kodmfc/finally_installed_the_fab9_elite_intake_manifold/
)Where the Power is Gained
1. Upper-RPM Breathing & Extended Peak PowerYour current setup drops peak power relatively early at 5,500 RPM. A stock Duratec plenum is designed to fall flat above 6,000 RPM. The shorter, high-velocity runners of the Fab9 Elite Manifold shift the engine’s volumetric efficiency higher. Your peak horsepower will likely shift from 5,500 RPM up to 6,200–6,500 RPM, allowing the Stage 3 head to finally breathe deeply. [1] (
)2.
The Stage 3 Synergistic Effect
When manufacturers or tuners test aftermarket intake plenums on stock 2.0L engines, they typically see a modest 5–10 wheel horsepower (whp) gain. However, dynamically, the more aggressive the cylinder head and camshaft profiles are, the more restrictive the factory plenum becomes. Real-world dyno results on highly modified naturally aspirated Duratec/MZR engines show that combining the Fab9 Manifold with aggressive headwork yields closer to 12–15 whp gains in the upper midrange and top end. [1] (https://www.reddit.com/r/MiataNC/comments/1kodmfc/finally_installed_the_fab9_elite_intake_manifold/), [2] (
), [3] (https://www.reddit.com/r/MiataNC/comments/1l1d72w/fab9_elite_intake_manifold_on_20_nc/)3.
Substantial Torque Curve Cleanup
Aside from the peak horsepower numbers, you will likely see a solid 10–12 lb-ft torque increase across the 4,500 to 6,500 RPM sweeping range. As noted by users on Reddit's r/MiataNC, a primary benefit of this manifold on a built engine is a significantly improved area under the torque curve with no loss of torque at lower RPMs. The aluminum plenum evens out the turbulent intake reversion caused by the aggressive cam overlap inherent to a Stage 3 head. [1] (https://www.reddit.com/r/MiataNC/comments/1kodmfc/finally_installed_the_fab9_elite_intake_manifold/)
Crucial Technical Caveats for the Plus 4
Throttle Body Matching Requirement: You cannot run the tiny stock factory throttle body on the Fab9 plenum and expect these results. You will need to budget for a 68mm or 70mm throttle body upgrade to avoid creating a new intake restriction right at the mouth of the manifold. [1] (https://www.reddit.com/r/MiataNC/comments/1l1d72w/fab9_elite_intake_manifold_on_20_nc/)
The "210 bhp Single-Plenum Ceiling":
On a naturally aspirated 2.0L Duratec, approximately 210 bhp is the maximum physical ceiling achievable using a single-throttle plenum. The physics of shared-air induction mean that to safely push past 210–220 bhp with that Stage 3 head, you would strictly require the independent, completely unrestrictive airflow of Individual Throttle Bodies (ITBs).Summary ExpectationCurrent Power: 180+ bhp @ 5,500 RPM Expected Power after Fab9 + 68mm TB + Map: ~195 bhp @ 6,300 RPM and a significantly broader, more eager rev range.
22 Plus Four KIMI
12 Plus 4 Sport OZZY
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
Luddite, I had the 85 CVH just before all the improved wood, paint and chassis treatments improving longevity. It was the second most underpowered of my 4/4 but the most entertaining and fun of all my trads.
22 Plus Four KIMI
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
Thanks for the heads up on your 85 4/4 John. My +8 is also an 85 but not registered until 86, perhaps slow to sell given around that time it seems likely that most folk may have wanted EFI as opposed to the Strombergs it was fitted with...? I suspect it must have been one of the last +8`s with carbs to have been built, if not one of the last to be registered for the road... I think it supposedly had something around 150 horses under the bonnet when new, no idea or care as to how many may have wandered off and grazing elsewhere, the main thing is that it has more than enough to keep me well enough entertained, to the extent that I have zero desire to think of ever replacing it..(-:
Am I correct in that your +8 was rebuilt, most likely it was built before the treatment improvements in 86 and onwards. The biggest metal work improvement was the painting of the wings seperately from the bodywork. My 4/4 and your +8 were most likely were painted with the the wimgs on, and the wing beading was painted over and the two inside metal surfaces below the beading were left unpainted. The chassis used to flex and crack the beading paint, and unless you kept on top of touching in the paint cracks (nearly every time you went out in it) water and moisture would get thru to the unpainted metal surfaces below and rust, plus if you had a mix of ally/steel body/wings electrolysis was accelerated. You could always tell back in the day if a pre-86 car had had it wings off for what ever reason, as most were refitted with new beading which was not painted over. The only reason I got rid of that 4/4 which was immaculate, was because of the continuous need to keep touching in the beading paintwork, everythime I came back from a drive.......local salty air envuronment didn't take prisoners.
So back then, if going on a touring holiday in addition to the grease gun, tools, I also kept a small pot of touch up paint and a brush, especially if holidaying in places with inclement weather eg Ireland.. If you think its interesting explaining to strangers why you are on your back in a hotel car park, grease gun in hand, imagine explaining away with the paint and brush in hand.........
22 Plus Four KIMI
08 Roadster FELIX
06 4/4 70th LOKI
77 4/4 SEAMUS
85 4/4 MOLLY
