Topics49,921
Posts838,310
Posts: 4 |
The needle on my temperature gauge generally moves slowly between 80 and 100c, moving towards 110 in heavy traffic or when stationary. About a year ago it started randomly rising to the stop. Mostly it falls back to the normal level but can do this two or three times in a journey of 15 miles.
I’ve replaced the thermostat and temperature sender unit but this hasn’t helped. I have also replaced the radiator and fan due to a leak.
Any suggestions?
Posts: 12,272 Likes: 325
Posts: 12,272 Likes: 325 |
Has it got a voltage stabiliser? Check and replace, also the earths on the instruments.
It could just be the gauge. A couple of years ago my temp gauge started reading high. I replaced the voltage stabiliser, the sender, the thermostat, and the water pump. Coolant temp measured with an infrared thermometer shows it to be completely normal but my temp gauge shows around 110C. I've decided to just live with it as putting a new temp gauge into a 40 year old dash would look silly.
Posts: 8,708 Likes: 416
Posts: 8,708 Likes: 416 |
Alan, your 2001 +8 according to wiring diagrams doesn't have an old style instrument voltage regulator. The instrument signal grounds are directly shared with each other so unlikely to be an issue if other gauges displaying normally. There is a green/blue coolant temperature signal wire from instrument in dash loom that connects with same colour wire in main chassis loom and on to engine loom and likely to ECU. The coolant temperature sensor signal also feeds to ECU on green/blue wire but no further info due to missing intermediate wiring diagram.
As Tim suggests your issue is likely with the dash instrument itself although you could check wiring connections as above. A cheap infra red/laser temperature sensor could be used close to temp sensor to allay fears of engine overheating.
Posts: 5,446 Likes: 133
Black Rat Charter Member
Posts: 5,446 Likes: 133 |
I spent over £2k chasing overheating on my 2001 Alfa 3 ltr Spider, it was the gauge DOH.
