8 members (BHV, John V6, banbury, JohnHarris, TBM, Haggispeed, Carbuilder, David_E),
152
34
Topics49,901
Posts838,045
Posts: 3,481 Likes: 42
Posts: 3,481 Likes: 42 |
Ivan, I was giving the recommended oil for a Limited Slip Diff like the one in my 2009 plus4. I have no idea what other diffs should use!!!, although I think it should be at least Hypoy 90
I wanted anyone with a LSD to be sure and check!
Cheers!
Posts: 367 Likes: 1
Posts: 367 Likes: 1 |
Posts: 12,265 Likes: 321
Posts: 12,265 Likes: 321 |
can someone tell me the best grease to use on the front suspension and the prop shaft. i have used Lithiun high melting point in the past but i do have some graphite grease but do noit know which is the beat to use? I use Molybdenum grease on the front suspension, and normal general purpose grease for the propshaft. Moly grease is supposed to be better for sliding applications, but to be honest I reckon frequency of application is more important than type. For the needle rollers in the propshaft, it's important not to use a very high pressure grease gun, as you can damage the needles. A single-handed lever gun is enough.
Posts: 113 |
I take my Plus Four to the factory for its annual service.It's a two hundred mile round trip for me but through lovely countryside.I've no real idea of what they actually do with the car but its seems a much better car when I get it back .They also give it its annual wash and brush up . Happy Easter to one and all Gerry
Verbum sapienti sat est.
