Topics49,911
Posts838,153
Posts: 4 |
Posts: 11 |
The Base Idle needs setting
After 20 years with a 1990 Plus8, I know a bit about the problems. If I can be of help PM/email me.
Posts: 61 |
Hi had this problem on my 2003 plus 8 while in holland last month thought the throttle cable or body was sticking. Brian Miller was on hand and gave this advice which worked. Due to starting the car from cold and pulling away without letting the engine come of cold start mode, the ecu has a funny and will not settle the engine to idle. Always let the engine idle a little while before pulling away. This was Brian's advice has his plus 8 does the same. regards Phil
Phil C Morgan Plus 8 4.0 Morgan 4/4 4seater 1.8 Volvo XC70 D5 220 Mazda MX5 2.0 Sport
Posts: 168 |
I think I understand what you mean - I have always been puzzled why my 1993 +8 sometimes revs up and down on zero throttle until it gets warm, and sometimes doesn't. I shall certainly try letting it idle for a while before driving off in the future to see if this makes a difference.
Fjemog
1993 Plus 8
