8 members (Haggispeed, JohnHarris, John V6, TBM, Carbuilder, David_E, Graham, G4FUJ, SailingTom2),
226
Topics49,901
Posts838,045
Posts: 6 |
Hello
I am looking for changing the nipples of the lower end of kingpins for a better access by 45° angle type. Do you know size and thread type of those parts I am a little lost in the BSP, UNF and want to avoid to purchase a kit of 110 pcs to find 2 units that match... Thanks in advance for your help
Posts: 105 |
Had a similar problem with my plus 4 and got round it by putting a washer under the grease nipple, the nipple was then pointing the right way for the grease gun.
Morgan 4/4 2004
Posts: 5,468 Likes: 172
Posts: 5,468 Likes: 172 |
Lower ones are 1/4 BSF and you will need washers to set the alignment. I used one washer on the off side and two on the near side.
Posts: 6 |
Thanks a lot Paul will take care of washers Cheers
