1 members (DJC), 336 guests, and 27 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
#99337 26/07/12 10:12 AM
I finally got round to having a poke around the battery on the Roadster. I'm now sure what happened to the last one. You can see on the first picture that the cables from the battery are held in place by two pretty flimsy P clips. I reckon that the clips broke & allowed the cables to flop onto the battery clamp stud ( which is where the short occurred).
Since I didn't particularly enjoy trying to get to the battery with flames licking around my fingers, exting I've done a couple of mods to try & avoid it happening on this car.
I've put a couple of cable ties around the cables & the cross member. If the clips break, hopefully the ties will allow the cables to swing below the cross member without touching anything else. As a bit of belt & braces, I've also screwed a plastic cap onto the stud ( the cables can't come into contact with the other stud). I'll let you know if it doesn’t work hide
3.7 Roadster
4" Ruston Procter SD Tractor
1905 Merryweather steam fire engine
Gone to Porsche
Gone to Porsche
Will you still be with us if it does'nt work oops
Thanks for the info - I shall have a look at mine this weekend.
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Time will tell...
But I survived the last one drive
3.7 Roadster
Good tip. Thanks
Ian
You could replace the factory cable clamps with these. Adell clamps are insulated and cannot break.
'65 +4 four seater
I was looking for those, or something similar - available from Vehicle Wiring Products in the UK.
I'm surprised MMC are using plastic P-clips for such an application.
Hmm. Good idea. I'll look out for some.
Ian
3.7 Roadster
Thanks, Graham. I'll get some on order.
Ian
3.7 Roadster
