5 members (CBY, RichardV6, John Winn, SailingTom2, +8Rich), 323 guests, and 35 robots.
+8Rich 102
John V6 64
M16 engine oil pan gasket
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,915
Posts838,218
MossyfromNZ
Thread Like Summary
DaveW, John V6
Total Likes: 2
by DaveW
We went for a run earlier, mainly to fill the tank for winter, because it was down to 1/4, and the GDI hasn't been nout much since Scotland.
After ten miles of normal running, we hit an incline and power vanished. It wasn't a single cylinder misfire, it was one of those brick wall flat misfires. It wasn't exactly safe where we stopped, but not busy either. The engine would tickover normally, but not rev. Just like the VW defeat rev limiter if you are familiar with that, but a lot more coughing and farting. It was impossible to turn round there, so when it cleared we got to the petrol station and filled up with Shell V Power.
It happened again a couple of miles after filling up, but a very mild flat spot. The engine otherwise ran normally. A few miles further and a slightly longer stutter. Within three miles of home it went tickover only. By holding the throttle right down it would stutter and cought then clear momentarily, before dropping t0 tickover again. We made it onto a filling station forecourt but were stuck for about half an hour, it just wouldn't clear. I was then at the point of calling the RAC, but knew that this would write the rest of the day off. Eventually after a lot of boy racer revving, it cleared enough to get home. In the garage it seems fine, but obviously I will be doing some checks.
The obvious cause is water in the fuel, but if so it's taking a long time to clear. The other alternative is the fly by wire throttle, and so I'll clean the contacts when I get time, and also check the Maf Sensor. There's no engine fault light showing.
Has anybody got any other ideas? I don't think it's ignition based. The only change I've made is ro rewrap the exhaust manifold and cat, but I can't see how that would cause this. thumbs
Liked Replies
by asbojohn
asbojohn
Check the butterfly in the throttle bodyit only has plastic teeth and these could be on the way out.
We've had similar lose of power issues with the clubsport.
1 member likes this
by DaveW
Thanks all. Well as I said it was running Ok when we got home.
Anyway, I cleaned the electrical plug to the throttle body and checked that it's a smooth action. In the electrical box on the bulkhead I've re-seated all fuses and relays. I will replace those relays. All the fuses needed shoving in half a mm, so that's a worthwhile check. My fuse diagrams have boxes A and B reversed, that's quite common on the GDI. The fuse listings for each box start top left, come down the left bank, then across to the right and up the right bank. Worth knowing.
I also re-seated the two main fuses.
Then I cleaned the MAF sensor. It starts and runs perfectly in the garage..................So we'll see what develops
1 member likes this
