10 members (JohnHarris, Image, JMcL, DalesPlusFour, Jensen1960, deano, Stephen888, John Winn, John V6, Pittsartist), 276 guests, and 32 robots.
+8Rich 102
John V6 60
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,180
Georgetoad, woolfie
Thread Like Summary
Graham, G4FUJ, Luddite
Total Likes: 2
#838502 02/13/2026 4:05 PM
by Calypso Red
Calypso Red
Here's a quick little question. I'm just getting round to changing 36 year old petrol hose on the +8 for new E10 resistant hose. The main lines are some plastic stuff that looks ok. It's mostly little connecting bits around the tank in the boot and some connections around the fuel rail and plenum under the bonnet that need replacing. I'm going for SAE J30R9 spec if I can get the right sizes. Admittedly, most of the sections won't be in the high pressure line but it looks nice and chunky, and I've got to use the meter length up some how!
The question is:-
Morgan in its wisdom has an 8mm connection from the top of the fuel tank which connects to a 6.5mm brass connection set in a plastic fuel hose, I'm assuming the return pipe from the high pressure fuel rail. Morgan used a single piece of petrol pipe for the join but there is no size marks. on it. What size hose would be best to use for this mismatch? If I use 8mm hose will I be able to get a seal on the 6.5mm connection just with a hose clip? If I go with a 6mm hose will I get it on the 8mm fitting without splitting it? Any suggestions welcomed.
Liked Replies
#838595 Feb 16th a 08:42 AM
by cerealsurfer
cerealsurfer
Sometimes it’s just a little outside in perspective that’s needed. That’s what forum’s like this are for. 👍👍
2 members like this
