Hi on my 1992 4/4 the brake lights come on as soon as the ignition key is turned to the on position and remain on all the time. Whether or not the engine is running. Depressing the brake pedal makes no difference to the light. I suspect a defective brake light switch. The switch is a Hydraulic type, If a wire is removed from the switch the lights go out. All the posts I have read online refer to brake light switches being faulty because the lights will not come on at all. Am I correct that my switch needs replacing or should I be looking for a different fault and if that is the case what should I try instead? Any help greatly appreciated.
