Topics49,843
Posts837,336
Posts: 1,444 Likes: 9
Posts: 1,444 Likes: 9 |
I have a terrible high pitched squeaking noise when I drive with the hood up and side screens mounted which is driving me nuts. I think I have located the noise to the side screen mounts. I might have over tightened them to much with the Tommy Bar. Loosening them of a bit seemed to help but now the noise has come back. Does anyone have a solution for this?
David 2020 Roadster 3.7 Dove Grey.
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
I have double sided sponge sticky tape attched to the bars from top to bottom where the side screen fits against the doors . But the side that touches the car leave the tape on over the adhesive .
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Both sides David? So if you take one side off, it is squeaking from one side only?
+8 4.8
It squeaks a little from the passenger side, Neil - but it is far worse on the drivers side.
I have double sided sponge sticky tape attched to the bars from top to bottom where the side screen fits against the doors . But the side that touches the car leave the tape on over the adhesive . Could be an idea. Actually, I tried some vaseline on the mounts but that hasn't helped.
I dare not write a reply to this I would get arrested but burst out laughing at it sorry I have a warped mind been in the mog club to long .  Could be an idea. Actually, I tried some vaseline on the mounts but that hasn't helped. [/quote]
I dare not write a reply to this I would get arrested but burst out laughing at it sorry I have a warped mind been in the mog club to long .  Could be an idea. Actually, I tried some vaseline on the mounts but that hasn't helped. [/quote]  Its all in the mind. Anyway, its the only thing I can think of using vaseline for
My old man told me chapped lips  he told me not to lick them .  Its all in the mind. Anyway, its the only thing I can think of using vaseline for  [/quote]
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Are you sure it's not the bonnet tapes? Try Vaseline over the bulkhead and cowl tapes.
Are you sure it's not the bonnet tapes? Try Vaseline over the bulkhead and cowl tapes. I don't think it's that Dave as the tapes were vaselined on Saturday when we were fixing the bonnet catches. I am not even convinced its the side screens. I just took the car for a spin to see if I could eliminate the noise and I discovered that when the side screens are lose I have the noise and when they are tightened to the maximum I have it. It likes a squeaking/ rattling noise. It doesn't sound healthy at all.
