0 members (), 275 guests, and 79 robots.
Topics49,847
Posts837,389
DazMog, The Impaler, tlchzj79
wally Offline OP
Hello,
i need some help with the ITG Sigma Kit - ordered it from Williams but did not get the fitting instructions, and so far no answer to my mail to them.
Some things are clear, looks like i can remove the airbox and use the plug there to put it on the new airfilter. But don't want to ruin something :-)
Anyone installed these Kit and can send me a copy of the fitting instructions via mail?
Thanks in advance and kind regards
Andreas
2003 Plus 8 35th anniversary, obsidian black
I wish I could help Andreas, i had mine installed at Williams, but happy to send you pictures If it helps ?
Craig Jezz
wally Offline OP
Hi Craig,
that would be perfect. Need to know how it is fixed towards the cowl and to the bulkhead.
THANKS for your help!!!
Andreas
wally Offline OP
Sorry, you can send it to andreas.schuster@bluemail.ch smile
wally Offline OP
Hi all,
thanks a lot for your fast help!!! I am really impressed - the members here in the forum are really helpful, not used from many other forums smile
Special thanks to Craig who made some detailed fotos of his engine bay last night.
With the pictures it was an easy job. Needed a little more than two hours, but it can be done for sure in an hour.
It is really straigt forward, remove hoses from standard airfilter, remove airbox (this is the hardest part because of the long stud bolts and locknuts).
Put the kit in and connect the hoses, thats it.
But only for right hand driven cars.
Because the hose for the engine ventilation must be turned towards the bulkhead, it touches the steering linkage mad
Removed the hose, shortened a bit and attached again with cable ties.
As last step i cut out a little of the plastic housing of the radiator to make space for the hose that brings the air to the filter box.
When the mesh grill arrives it is close to invisible.
Testdrive done, nothing lost on the way and no breakdown grin2
Feels like there is a bit more power, but maybe it is only a wish wink
Kind Regards
Andreas
Nice job Andreas 👍, you just need a Morgan sticker now 🙈
Craig Jezz
wally Offline OP
Looks definetly better with Morgan sticker. Think i need that smile
