Further development of the handbrake conversion.A little background reading indicates that the shock absorber mounting hoop was introduced in 1991 for the change over from Armstrong lever to gas filled telescopic shock absorbers. The rod operated handbrake system was changed to the cable system, mounted on the rear of the hoop, when Morgan changed the braking system of all models, not just the +8, from Girling to Lockheed in 1993.
This handbrake conversion first used plates made from the casing of a washing machine. However, better materials have become available and a simpler fixing method has been developed. The plates are now available in 6mm stainless steel with some elongation of two of the holes to allow for adjustment when positioning.
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8813_LI-2.md.jpg)
Orientate both plates as shown but not in mirror image. Holes A & B are for attaching the plate to the hoop with a U bolt. The hole C is for bolting on the brake cable sheath and the slot D is for bolting the plate to the original hoop bracket with a long bolt, M8 x 65mm.
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8831.md.jpg)
First, completely slacken off the handbrake adjuster. I use an 8mm spanner on the off side cable to stop it rotating and a 7/16” ring spanner, or better, an 11mm (3/8” drive) deep socket if you have it, on the inside lock nut of the adjuster. Leave the outside lock nut in position.
Unbolt the cables from the brackets at the rear of the hoop using a 5/8” spanner to steady the brake cable blocks. Keep the ½” UNF nylock nuts.
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8832.md.jpg)
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8835.md.jpg)
An M8 65mm bolt is used to bolt the plate to the original hoop bracket.
This picture shows the plate prepared with the long bolt and fixings ready for offering up.
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8822.md.jpg)
Attach the plate to the hoop with the U bolt through holes A & B, and at the same time attach the long bolt to the hoop bracket.
Keep the plate vertical and the long bolt horizontal as you tighten the bolts. Install the second bracket in the same way.
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8811.md.jpg)
Next, locate the thread of the brake cable block through hole C, do not add any washers. Apply some thread lock (Loctite or similar) to the original imperial ½” UNF nylock nut and tighten, keeping the cable level. Repeat this on the other plate.
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8804.md.jpg)
The following picture which shows everything re-attached.
Now you can adjust the handbrake. Lift the rear wheels off the floor to assess the action of the hand brake. If slight adjustment is needed tighten or release the off side cable a little before nipping up the lock nut. If you have any concerns then consider a formal handbrake adjustment. For instructions see:-
https://www.gomog.com//allmorgan/APBRAKES.htmlWhere the main handbrake cable emerges from the transmission tunnel it may be a little close to the differential. The cable can be moved a bit to the near side away from the differential with a retaining clip bolted to the floor. The off side cable sheath passes naturally in front of the Bump Stop and can be cable tied a couple of times onto the hoop. If you wish to add some protection to both handbrake cables, tie wrapped petrol pipe is easy to install from the adjuster to the brake drum.
![[Linked Image]](https://www.tm-img.com/images/2021/01/20/IMGP8806.md.jpg)
The original configuration of the cable can be easily restored since it does not involve any cutting or drilling.
Declaration-1; I declare no financial interest.
Declaration-2; No domestic appliances were harmed during this modification.
