SORN
New
Topics48,367
Posts813,395
Members9,215
Update 51 - Dash and Electrics
We found Woodstock's dash was snapped when we stripped the car down - it was not not suitable to be used again so I've made a new one.
With Woodstock we've decided to keep the dash more original so the old dials have been used along side the telemetry set up and digital dash display.
Also have used the buttons found on more modern Mogs..
Posts: 1,484 |
Lovely. How are you going to use the LED/LCD?? Cheers,
Posts: 2,403 |
Lovely. How are you going to use the LED?? Cheers, I'm assuming you mean the LED's in the top of the digital display. These are programmable and I've set them to sequentially illuminate every 200rpm for the last steps to the red line. At the max RPM they flash all together. If you keep going the Rev limiter cuts in. It's pretty easy to code up with the management software. This dash has 4 screens all controlled by the 4 buttons on the RHS. You can display any information that the Telemetary system has (including split times and lap time predictors based on historic lap information) or any info the ECU chucks out. The digital dash has all the warning lights required to be road legal and uses indeglo to illuminate in the dark when you turn the side lights on. It's made by RaceTechnology
Posts: 2,361 |
Instagram - WilliamsMotorsportuk - Lawrie Mills(Chunkylozza) Youtube - ChunkyLozza
Posts: 4,896 |
That looks good, I personally hate car electrics.
Adrian
Posts: 14,009 |
That looks good, I personally hate car electrics. Is that because you can't polish them Adrian?
Posts: 5,653 Likes: 4
Posts: 5,653 Likes: 4 |
That looks really good and I like the mix of old and new technology.
Martin (Deano)
Posts: 2,814 |
Will you still use Woodstock on the road? Gerry.
Gerry
Posts: 26,763 Likes: 425
Posts: 26,763 Likes: 425 |
Looks even better in the metal. Great to see the progress
Also good to see Mr Cripps in action.
