Topics49,847
Posts837,391
Posts: 11,616 Likes: 43
SogMog flood defences
As an addendum to recent posts regarding the flooding to my village of Croston and the flooding of my house and Morgan, we have bolstered our defences with sandbags infront of the garage
Hopefully SogMog will not be repeated
The drive is sloping back to the garage with a soak away infront of the garage door so my son and I have been creative, thinking that we can divert the flow of any flood water with an arrowhead of sandbags
Posts: 5,013 Likes: 32
Posts: 5,013 Likes: 32 |
Awful... the whole thing is just devastating for everyone effected.
+8 4.8
Posts: 5,587 |
I hope you are right and the water doesn't get anywhere near you , we are all hoping for the best outcome !
Posts: 14,009 |
Fingers crossed for you Stewart....and for anyone else in the path of Frank!
Posts: 37,407 Likes: 977
Posts: 37,407 Likes: 977 |
Very neat and purposeful.
Good luck to all of you in the path of the next bout of high winds and rain.
Posts: 1,948 |
Stewart, where does your ACO soak away to? Water may back up through this and thwart your cunning arrowhead design. So don't forget to put some bags inside your garage behind the door also.
Good luck.
Stuart "There's no skill substitute like cubic inches."
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Hope all passes without incident.
Richard 1976 4/4 4 Seater
Posts: 9,545 Likes: 132
Posts: 9,545 Likes: 132 |
Stewart, any airbricks or vents in your walls? Worth blocking them as well to prevent water getting that route in.
Posts: 1,004 Likes: 31
Posts: 1,004 Likes: 31 |
Steward, whishing you luck when sitting out the next wave!
Some advise from The Netherlands (2/3 of our county has to be protected against flooding), behind the V shaped dyke of sandbags, I would put an extra one directly in front of the door. Golden rule: shorten the coastal line. You also create an additional line of defence. Finally, have pump ready so you can pump out water as soon as it comes in.
Good luck! BertR
2025 Plus Six - 1909 2009 Roadster 1983 4/4 4str Board member Morgan Sports Car Club Holland ('21)
Posts: 1,647 |
Best of luck Stewart.....and everyone else at risk.
I was pondering in my mind about the idea of getting the Morgan raised up on ramps/blocks, just in case the water gets through the sand bags.
Jaguar F-Type V6s roadster 2009 Harley Davidson XR1200 1986 Honda VFR750F (RC24)
Just thinking Stewart...do you have axle stands or some scaffoling planks (or similar) you could get the car up on? Might just save things.....
