2 members (RichardV6, Alan Patterson), 232 guests, and 34 robots.
+8Rich 97
Luddite 54
Topics49,904
Posts838,088
#530482 28/08/18 08:15 PM
Bimini top
to avoid exhaust odor in the car with the bimini top i made a exhaust tip with the end welded shut down and cut a opening at the underside…. test will be for as soon it doesn't rain…. so not yet tomorrow … mad grin2
17 Comments
belgiumbarry #530484 28/08/18 08:20 PM
A good idea I hope it solves your problem.
belgiumbarry #530488 28/08/18 08:31 PM
thanks Richard . Must find out.... o well, it didn't cost a fortune for a test...
2004 GTN #5 sold
1989 Plus 4
belgiumbarry #530503 28/08/18 09:00 PM
Interesting. Look forward to the test result....
belgiumbarry #530537 29/08/18 06:14 AM
Probably a turbulence thing from the rear wheels occurring, with the fumes from the exhaust being pulled back by negative pressure in the wheel well, as our noses sit relatively close to the wheels hence the pong.
What type of wheels do you have?
If you can borrow another style see if the issue alters.
IE go from wires to alloys and visa versa.
Mark - No Longer driving
belgiumbarry #530556 29/08/18 07:46 AM
Good idea Mark , i have wires now….
but i suspect a negative pressure zone due the bimini top without a rear window…. i once had a '70 Corvette ( T top targa) on which the rear window could be removed. Later years they made it fix due problems with exhaust gases in the car … could be the same problem here.
With the door windows on it's even worse…. as expected.
2004 GTN #5 sold
1989 Plus 4
belgiumbarry #530846 30/08/18 08:18 PM
Ok, tested today…. it's much more better but with side windows there's still some exhaust smell... without it's OK . Ofcourse , when one is concentrating on odor , you always smell something...
so , problem not 100 % solved. O well, no big deal , keeps us thinking... grin2
2004 GTN #5 sold
1989 Plus 4
belgiumbarry #530847 30/08/18 08:20 PM
That's good you're getting there.
belgiumbarry #531047 01/09/18 10:31 AM
Try simply making the exhaust a little longer -- 3 inches should do it. Worked for me.
belgiumbarry #531074 01/09/18 05:15 PM
thanks griffo .… but the exhaust was already "long" … sticking out as far as the overriders in the back. It looked already to long.
2004 GTN #5 sold
1989 Plus 4
