0 members (), 227 guests, and 38 robots.
+8Rich 101
John V6 57
Topics49,911
Posts838,152
Georgetoad, woolfie
14 Images
The TM in Talk Morgan
Pre-Production Morgan ThreeWheeler
For those who are having problems viewing Charles Morgan's photos, with his permission, here they are for your viewing pleasure.
More information can be found on the Morgan 3Wheeler micro site
14 Comments
AQM Offline
Originally Posted By Jays
Looks like a belt drive from the gearbox to the rear hub! Guess that ties in with the engine which is H-D?
The engine is apparently an S&S from S&S Cycles.
And, yes, it's belt drive (sounds like I know something, but the proof is in the pictures, plus I was told so in an email from Morgan Motors).
[edit: The gearbox is from Mazda, just in case you didn't know]
Originally Posted By Hans Hill
Will start a listing for my one then...and it is RHD!
Guess it will be a lot cheaper too!
Yes, your's will probably be cheaper, but the Morgan will be all new and have seatbelts (lol).
With regards to RHD/LHD, MMC will make both, so you get to choose which one (depending on the laws in the country of registration, of course).
So if you need a RHD, that is what you will be getting. If you need the other, you'll get one of those.
Belt drive hub in the piccy.
I thought the original blurb said it was going to be shaft drive, single sided swingarm (anyone remember from the factory tour a few months back?)...
Cheers,
Green & Grown Up
Green & Grown Up
Belt drive hub in the piccy.I thought the original blurb said it was going to be shaft drive, single sided swingarm (anyone remember from the factory tour a few months back?)...Cheers,
You are correct Sir. The question was how would the shaft fit with the wheel centered (or something like that) sherlock
Interesting Pics though. It will be a nice car I am sure. notworthy
Looks like a well marinised dash panel! smile
oh that's what it is! at first glance I thought it was a ghetto blaster, should have put my specs on laugh
So,
Who tried to add a photo to those already here? Not to worry, we know what the thread is.
Further photos have appeared on yfrog, which give a really good indication of how the rear end is put together.
Sure enough, no single sided swingarm. Shaft drive from the gearbox to the 90 degree gearbox you see here, with belt drive from that to the wheel. Adjusters for the rear axle to tension the belt (just like a m/cycle) can be seen and it all fits between 2 approx 4.5 gallon fuel tanks - hopefully with enough travel to drop the swingarm sufficiently to remove the axle when the rear wheel needs to come out. Rear tyre is a Toyo car type.
Anything else? Probably lots, but I'd really like to see this thing in the metal now. thumbs Wound the other half up by saying I'd bought another Mog (then let her see the Vitesse 1/43rd scale +8 on the dining room table laugh2 ). No doubt I'm still in trouble though swmbo laugh2
Cheers,
