0 members (),
467
46
Topics49,841
Posts837,323
My new Morgan+8
At the end, after all these years, I got my +8
Cheers, Roland
Posts: 321 |
Super looking Mog Love the MK dash and wheel Ditto. Enjoy the car.
3.7 Roadster Porsche 964 C2 JCW Mini Cooper S Cab BMW F750GS +4 4 1995-2002 / LM 62 +8 2002-07
Posts: 2,272 Likes: 7
Posts: 2,272 Likes: 7 |
Good morning, the +8 is build in 97. So it's a "long door" model if I'm right. 1997 was the changeover year, so it could be either. The indicator repeaters on the scuttle panel suggest to me that it is a short door car. The other method to differentiate is the dashboard , but with the MK version being different that is not possible. However with MMC you never know, and it might be a "hybrid" of the two. But nevertheless it is a lovely car. Congratulations.
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
I think it's a short door from the shape around the front edge of the rear wing. But it could easily be a hybrid. Is the bulkhead stainless steel?
Posts: 988 Likes: 14
Posts: 988 Likes: 14 |
Did not the short door models have windscreen demister vents?
Brian
Jersey and Spain
Posts: 28,892 Likes: 350
Posts: 28,892 Likes: 350 |
Yes Brian. When the long door came in there wasn't room for them, so electric windscreens from then on.
Posts: 1,943 |
Actually on My +8 Bitsa I used a long door chassis but installed a short door body tub. I know it is a long door chassis because the crossmember in back of the seat has been flipped, lowering the spring perch. As well the later seats are modified on the outboard edge to clear the spring perch allowing the seat to slide back farther giving more leg room. I did not realize this until I installed the later Roadster Type seats.
Button
Posts: 24 |
Very interesting. It doesn't have demister vents but the windscreen is heated... And I will have a look to the bulkhead
If you can post a side on view of the bulkhead, door and rear wing we should be able to identify which body.
Having looked closer, the wings look like Superform, so I'm leaning towards early long door.
Posts: 24 |
There are 3 new pictures and I hope it helps to find out if it is a long /short door. ANd even the question if the wings are superformed would be very interesting for me.
Thank you
All the best, kwa heri Roland
Morgan Plus Four MY23
Posts: 37,403 Likes: 977
Posts: 37,403 Likes: 977 |
Long door and superform I would say, more importantly though a beautiful car  I have had a 1994 short door and my present 1999 long door and unless they are together it's not easy to tell. If you run your fingers along the inside lip of the wing you can normally tell whether it has the steel former inside it to identify the wing type. The indicator on the scuttle has me puzzled for a long door superform though but hey it's a Morgan  .
