Topics49,880
Posts837,766
Posts: 1,646 Likes: 1
Solar Panel Array and Tesla Powerwall
The need to draw power from the grid is going to be a lot less going forward!
Posts: 8,688 Likes: 495
Posts: 8,688 Likes: 495 |
Wow, that some installation
Did it need planning approval, or have you got understanding neighbours ?
Posts: 1,646 Likes: 1 |
Planning is needed on ground array larger than 9 sqm which is basically anything more than about 6 panels.
It is only possible to see the array if you ae in our field or climb up over a 6 ft fence to see in.
Posts: 1,889 Likes: 16
Posts: 1,889 Likes: 16 |
We are building (started with the shop/garage and placed 20 panels on top. Fortunately our state law states the home owners association cannot object to a roof top array
In the UK it is generally ok to put panels o the roof without planning if it is not a listed building. Putting them on the ground is a different prospect.
Aero 8 GTN. #10
Posts: 987 |
That’s an incredible array, well done sir.
Posts: 15,794 Likes: 15
Posts: 15,794 Likes: 15 |
We were an early adopter in 2011, so now we get £0.54p a Kw/h for generating power. This is index linked.
The last quater we received £654.00, tax free. For the year 2018 we received £2071.00.
This generous feed in tariff has ended, but existing agreements are valid at the contracted rate, in our case to 2036.
We have spare roof space, After seeing what the addition of a battery and control unit has done I'm tempted to add another 4kw/h array: even without any FIT it still makes sense and would reduce our consumption of grid power to close to zero, at least during the summer.
Posts: 6,959 Likes: 117
Posts: 6,959 Likes: 117 |
£0.5378p! We just got £642.48. That's with 4Kw and battery back up.
