5 members (DJC, Luddite, ChrisConvertible, IcePack, Zach), 225 guests, and 26 robots.
+8Rich 99
John V6 57
Topics49,911
Posts838,147
#650743 15/07/20 03:02 PM
Wear and tear
To the right is how my Roadsters clutch pedal clevis pin looks like after 56000kms on the road shocked2
2005 Roadster 3.0 S1
1960 MGA Roadster
Regards Aage
21 Comments
Hamwich #651020 17/07/20 09:05 AM
Originally Posted by Hamwich
This is exactly the reason why every Morgan owner needs a lathe. It would be a complete doddle to make up a replacement in silver steel and harden it rather than just replacing it with another mild steel pin that's going to wear again.
Would that not wear the hole in the clutch pedal? If that's the case I'd rather replace the clevis pin every so often as it's not much of a job.
1972 4/4 2 Seater
CooperMan #651024 17/07/20 09:33 AM
Periodic lubrication of these is on the servicing schedule, but I suspect is often missed, if the pin is dry & not rotating that's the classic photo of the wear you get
So, a little job for the weekend chaps ?
Absolutely, unless the forward edge of the carpet looks a bit oily it hasn't been done.
tmg513 #651036 17/07/20 10:56 AM
Possibly I suppose. As Cooperman points out, best to ensure it's regularly lubed.
That also what I thought, it is surely sacrificial.
Like king pins?
Hawki #651047 17/07/20 01:03 PM
Lubrication, Lubrication and yet more lubrication is the answer laugh2
Yes Richard. I have just got the oil can out. Now to fix the back ache.
John V6 #651069 17/07/20 03:46 PM
laugh2 laugh2 Every little helps John..
Having (in my early years) worked on many vehicles with rod brakes I would rather change a dozen worn clevis pins than a dozen rod ends! As Stirling Moss said when someone criticised him for not changing down and using the brakes more often “which would you rather pay for old man, brake pads or gearboxes?”
Lube helps a lot.
BR
Colin
BR Colin
Hamwich #651134 17/07/20 09:40 PM
My Myford Super Seven lathe made this an easy job. I made up the new clevis pin out of a standard 10mm bolt. Hardening is absolutely not necessary in my opinion as these clevis pins can be replaced in a few minutes. A hardened pin will just move tear and wear over to the pedal and the clutch master cylinders connection fork
1960 MGA Roadster
Regards Aage
