8 members (Mike D, John V6, KennethM, Dek, thelastgizmo, Image, JMcL, Lance), 340 guests, and 29 robots.
+8Rich 101
John V6 63
Aero 8 S5 Sound System
EV beckons....
by TBM - 14/09/26 09:45 AM
Topics49,914
Posts838,196
Georgetoad, woolfie
3 Images
osten Offline OP
Is my oil level too low ? (2019 M3W)
Evening gentlemen,
I'm now over the 3000 km mark and decided to have a look at the oil tank after today's drive and I'm not exactly sure if what I'm looking at is where it should be. My owner's manual mentions a dipstick to measure oil levels but mine doesn't have that.
Is my oil level too low ? If yes where should it stand.
EDIT: I found a small leak at the bottom of my crankcase from what seems to be a bad seal. Pictures attached.
Piloting Saint Ex the Morgan
5 Comments
did you start the motor and run it a few minutes. The sump needs to be pumped out first before you check it. there could be up to a quart in the sump. Once you have done that, the oil should be between the two indicators
Rodger
2004 Plus 8 (wife's)
I would add some oil.
There is space enough for it.
In my M3W I kept the level to cover the lower indicator
Hannes
once: Green M3W; 2013
now: Red 4/4 Sport; 2011
osten Offline OP
Car was driven just before I took this picture. I also found the reason why the oil level dropped it seems I have a small leak at the bottom of my crankcase (the seal I imagine).
Yes, you have a crankshaft oil seal leak by the look of it. If the engine has just been run for at least a few minutes, to scavenge the oil back to the tank, then the oil level is low. It should cover the lower level plate but not go above the higher (LH in photo) plate. Only check the level after a run, let it settle for a couple of minutes then check it. Checking it cold can give a false level.
Always hot level
