8 members (John V6, auster, sprinty, Chris Cosher, Simon, TalkMorgan, TBM, nestor59310),
325
33
Topics49,914
Posts838,185
Posts: 367 Likes: 1
Roadster Rear Shelf Storage
This is my solution to the useless storage under the rear parcel shelf. I went through 3 of the plastic rubbish on my +4 in 2 years of ownership and the tray in the Roadster is cracking after a year (less miles). On the +4 I tried a plywood unit with Aluminium Angle at the edges. It was quite heavy and dimensionally I did not get it right. This time I built a patern in Cardboard and had a sheet metal shop fabricate it in 2mm Aluminium. I have lined it with car acoustic foam (yes you could use neoprene). Very pleased with the result and gives much more usable space. I have just had a Roll Bar fitted so there is a removable flange on each side so it gets support at the sides but can be slid in between the Roll Bar support frame.
Posts: 1,558 Likes: 5
Posts: 1,558 Likes: 5 |
Top fix to an old problem
Posts: 3,727 |
An excellent solution  - Well Done that man! My Roadster tray base was punctured in three places following the Thumping the rear axel gave it on my 5017 mile trip, not just by the Bellhousing.
Posts: 27,849 Likes: 766
Posts: 27,849 Likes: 766 |
Stunning. What was the cost? Do you think it would work on a 97 +4?
Posts: 28,912 Likes: 354
Posts: 28,912 Likes: 354 |
Looks a great answer to an old problem...
Posts: 367 Likes: 1
Posts: 367 Likes: 1 |
It was £120 which is not so cheap, but I figured over the years it will even out because I bet the plastic is not so cheap either and the warrenty does not run for ever.
Posts: 367 Likes: 1
Frank Mine will get its real test next month on the trip to Le Mans. I took alot of care to make sure it did not reduce any of the clearances to the axle and bell housing but only a fully loaded car and Belgium pave will prove it.
I reckon, for a one off special, that's a very good price Andy. Maybe we could all send you some dimensions and then take a trip up to Scotland to collect the finished articles...
Posts: 1,004 |
Brilliant job. Well done!
Posts: 1,103 Likes: 2
Posts: 1,103 Likes: 2 |
Very impressive! I would be interested in one if a bulk purchase was negotiated. I need to check the dimension of my 4/4though.
Keith
Car 54 - 'Le Mans 62' 4/4 Supersport OxMog Member (and associated with CranMog and SwanMog)
