8 members (TeddyAds, Aeromax51, MOG42, GrumpyPa, sprinty, CooperMan, MJF, Image),
244
43
Topics49,843
Posts837,348
Posts: 75 |
the Morgan Lubrication Kits can be bought from our website. What advantages are there to buy this kit? Regards, Bosse
4/4, Sport White (Ivory) 2011), Smart Roadster Coupé Yellow, 2003
Posts: 37,405 Likes: 977
Posts: 37,405 Likes: 977 |
Yes I agree with your sentiment Dave - besides a good tightening up of your "nuts and bolts" of the suspension and crossarm never goes amiss. You don't want anything coming adrift at an inappropriate moment do you
Posts: 541 |
Bosse, Du kan smörja framvagnen från motorrummet coh slipper hissa upp bilen. Kenneth i Löddeköpinge.
Ken in Sweden - SM7CQY Mr BRUM - Morgan Roadster 2004 Series 1 in Royal Ivory
Posts: 75 |
Du kan smörja framvagnen från motorrummet (You can lubricate the front from the engine compartment) Thank you! But I think it's easy to raise the front end and grease directly into the easily accessible grease nipples. In addition, the bearings are better lubricated in the unloaded condition. Regards, Bosse
Posts: 478 |
The Zerks - otherwise the giggling will start again :-) - should be 1/8th BSP - I say should be because my owned-from-new +8 has 1/8th BSP on the nearside and something that is not 1/8th BSP on the offside.
I am toying with the idea of fitting a remote greaser because accessing the nipples zerks with AVOs is a bit of a pain but would grovel on the floor afterwards to clean up and check fittings
Posts: 3,727 |
I'm not a fan of remote greasing. I'd rather get down & dirty........ With all of your Innovations Dave, you surprise me .  You still have to get down and under to wipe away the ejected oozing excess so just wipe your brow half way through and you'll feel at home all the same.  .
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
I'm not a fan of remote greasing. I'd rather get down & dirty........ It's not the getting down but getting up again is the problem.  I am not sure if Elaine knows what she has started.
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 534 |
I'm not a fan of remote greasing. I'd rather get down & dirty........ Sadly, I don't have a garage ( let alone a carpeted garage  ). Lying on a bed of wet gravel to grease said nipples zerks makes the remote greasing kits seem very attractive
3.7 Roadster 4" Ruston Procter SD Tractor 1905 Merryweather steam fire engine
Posts: 3,727 |
One might consider this blatent 'marketing' Normally I would agree, but the Nipple Ship put these kits together after Robbie sorted out the requirements for his Mog with them. I see now someone else is now buying the parts and selling them via Miscellany. There have been so many requests for info on here that the direct contact must be worth something to Members? I got my standard set after Robbie put me in touch with Nipple Shop. BTW, Anyone want a Waddesdon Rally Plaque for £5. + £2.50 Postage for Help for Heroes?
Posts: 22,356 Likes: 353
Posts: 22,356 Likes: 353 |
Can we please stop calling them Zerks! I've just been out cleaning the wires, and took the opprotunity to pump a few shots in, and take a general look around. It's true that I have the luxury of carpet tiles, but over my whole motoring career, I've never had a car without nipples, and I didn't always have a garage. Pre-marriage, I dug a shallow grave between the flagstones on the front lawn and in doing so exhumed somebody's dog. Most unfortunate. So I laid in the earth pit on an ex WD blanket to service the Dolomite propshaft nipples of which there were three. Each one having a grub screw to take out first and replace after inserting the nipple, greasing, then removing. It was also necessary to rotate the prop to access each one. MGB's & Midgets have two or sometimes three a side on the kingpins, and usually I took the wheels off to make sure that the grease was going where it should be going. You don't need to do many kingpin replacements to realise that it's important to make sure it gets where it should. So that's why for me, remote greasing is unthinkable.
