1 members (moggin),
217
80
Topics49,873
Posts837,706
Posts: 27,817 Likes: 749
Posts: 27,817 Likes: 749 |
Posts: 61 |
Problem is there's 2 lovely ball joints at either end!!
Posts: 14,976 Likes: 2
Posts: 14,976 Likes: 2 |
Problem is there's 2 lovely ball joints at either end!! In that case technic Lego.
Richard 1976 4/4 4 Seater
Posts: 836 |
Problem is there's 2 lovely ball joints at either end!! In that case technic Lego. It may have as well been technic Lego, though, that might have been stronger...
Posts: 61 |
As predicted the link has just snapped again!!
Posts: 3,841 Likes: 11
le Asbo du Bling Talk Morgan Addict
Posts: 3,841 Likes: 11 |
Simmo, from what I can remember the set up on yours looks different from mIne, one online the cable runs through the sort of drilled bolt you get on bicycle brakes.
Slowly going green
Posts: 14,748 Likes: 158
Posts: 14,748 Likes: 158 |
Rod and ball joint linkages are quite comon on motorcycle pedals. It would be easy to adapt something from a motorcycle dismantler.
Posts: 37,437 Likes: 983
Posts: 37,437 Likes: 983 |
B*gg*r that is frustration - I bet you feel like putting a hand throttle on it  Good luck with it.
