1 members (moggin), 217 guests, and 80 robots.
+8Rich 78
Oil level reading
by moggin - 05/09/26 01:58 AM
Topics49,873
Posts837,706
Or use Mercanno
Simmo Offline OP
Problem is there's 2 lovely ball joints at either end!!
In that case technic Lego. hide smile
It may have as well been technic Lego, though, that might have been stronger...
Simmo Offline OP
As predicted the link has just snapped again!! swear
le Asbo du Bling
le Asbo du Bling
Simmo, from what I can remember the set up on yours looks different from mIne, one online the cable runs through the sort of drilled bolt you get on bicycle brakes.
Slowly going green
Rod and ball joint linkages are quite comon on motorcycle pedals. It would be easy to adapt something from a motorcycle dismantler.
B*gg*r that is frustration - I bet you feel like putting a hand throttle on it mad2
Good luck with it.
