2 members (Alistair, stumog),
351
33
Topics49,843
Posts837,336
Posts: 3,643 |
Cracking car and photos. Congratulations.
Posts: 89 |
Are the universal joints fairly easy to change on an S1, at 47k miles mine are getting intrusive whenever I turn left?
Posts: 859 Likes: 1
Posts: 859 Likes: 1 |
George, I thought the factory had replaced almost the whole car since you have had it.
Honda S2000 Lexus UX 250h Toyota Auris Hybrid
Posts: 536 |
Gin
You can get a similar noise to uj wear if the wheel nut on opposite side to turn is slightly loose; in your case right hand side. Worth checking it's correctly torqued up.
Cheers
Philip
Philip
1985 Plus 8 four seater Malone F1000 - track car
Posts: 89 |
You were correct the wheel nut had worked loose, wheels torqued up correctly with no noise, apart from the n/s wheel bearing that needs replacing!
Cheers
George
Posts: 536 |
Hello George
Glad it's sorted. Took me nearly 2 years to work it out during which time I replaced half axles!
Cheers
Philip
