3 members (John V6, Bunny, Mike D),
264
32
Posts837,998
Posts: 552 |
The front box of my original (as far as I know) standard exhaust of my 1988 cvh 4 seater is showing some corrosion, and so I am thinking it will need replacing at some point in the not too distant future. It hasn't fallen off yet and this doesn't seem imminent, but I thought it might be worth starting to research the best option. In my ownership, have taken the view of replacing things as they have worn with an improved version if one is available.
The back box is also showing signs of age, so I am probably looking at options from the downpipe back
I wouldn't mind a more tuneful exhaust note, but don't want to end up with anything too boomy - I do quite a few miles in the car. but other than that I am open to suggestions
So answers on a post card please!
Posts: 2,568 Likes: 98
Posts: 2,568 Likes: 98 |
I have 3 CVH exhausts I don't need from various times over the last couple of years
1) Rear exit: sporty 2) Loud side exit: 111db 3) Sporty side exit: 97db
if you are interested let me know.
Posts: 8,015 Likes: 1
Posts: 8,015 Likes: 1 |
A Geordie so that means you are tight with the cash . John Worrall ( Heart of England Morgans ) has 1 CVH manifold and down pipe left in stainless steel a 4 into 2 into 1 system . Mike Duncan can put you a +8 silencer ( fits to chassis under the nearside door ) on a straight through pipe in s/steel and it will last you years also sound better and give you a bit more power . The front box of my original (as far as I know) standard exhaust of my 1988 cvh 4 seater is showing some corrosion, and so I am thinking it will need replacing at some point in the not too distant future. It hasn't fallen off yet and this doesn't seem imminent, but I thought it might be worth starting to research the best option. In my ownership, have taken the view of replacing things as they have worn with an improved version if one is available.
Posts: 4,612 Likes: 15
Posts: 4,612 Likes: 15 |
Posts: 82 |
Harpers Watford, i got my 4 branch and system from him, sounded, looked luvly.
ABBO Morgan 2005 Roadster Morgan 1986 4/4 4str Prev Morgan 1953 +4 DHC Prev Flippin Pongo 3008 Hybrid
Posts: 1,111 Likes: 17
Posts: 1,111 Likes: 17 |
cerealsurfer, sent you a PM, regarding your spare exhausts.
From experiance, you are better off without a backbox on a Morgan, otherwise you will always ground it on bumps etc..
Posts: 28,909 Likes: 354
Posts: 28,909 Likes: 354 |
Not had a problem with the rear box on mine - just the end of the tailpipe, which now looks like a 'D' on it's side, except the flat part of the D, which is on the bottom, is kinked in/upwards towards the curved top part, if you see what I mean...
Posts: 552 |
Cereal, I tried to PM you but you are over limit - I am interested in some of your stock, Can you pm me?
Posts: 552 |
So answers on a post card please! I am not a geordie, I just live here! As a merseysider by origin, I would probably rather thieve the required parts (well, de doo doh, dont de doh, eh Laa?) Cheers for the tips, I will have another look at heart of england site again. I am hopeful one of cereals hand me downs might suit
Posts: 552 |
Thanks to Cerealsurfer, I now have a nice new to me tubular manifold, neatly wrapped and a sporty rear exit pipe.
Just need to get it fitted, might have a crack myself once I have done a bit of research.......
