Morgan Aero 8
1 members (Graham, G4FUJ), 387 guests, and 42 robots.
+8Rich 89
Topics49,841
Posts837,324
Christoph
Cracking car and photos. Congratulations.
Ian
Gin Offline
Are the universal joints fairly easy to change on an S1, at 47k miles mine are getting intrusive whenever I turn left?
George, I thought the factory had replaced almost the whole car since you have had it. hide
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Gin
You can get a similar noise to uj wear if the wheel nut on opposite side to turn is slightly loose; in your case right hand side. Worth checking it's correctly torqued up.
Cheers
Philip
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Gin Offline
You were correct the wheel nut had worked loose, wheels torqued up correctly with no noise, apart from the n/s wheel bearing that needs replacing!
Cheers
George
Hello George
Glad it's sorted. Took me nearly 2 years to work it out during which time I replaced half axles!
Cheers
Philip
