Morgan Aero 8
7 members (TBM, GrumpyPa, Morganmike, Alistair, DPEvans, ChrisMorgan, piquet), 290 guests, and 27 robots.
+8Rich 89
by stumog - 26/08/26 10:24 AM
Topics49,842
Posts837,331
Christoph
Cracking car and photos. Congratulations.
Ian
Gin Offline
Are the universal joints fairly easy to change on an S1, at 47k miles mine are getting intrusive whenever I turn left?
George, I thought the factory had replaced almost the whole car since you have had it. hide
Honda S2000
Lexus UX 250h
Toyota Auris Hybrid
Gin
You can get a similar noise to uj wear if the wheel nut on opposite side to turn is slightly loose; in your case right hand side. Worth checking it's correctly torqued up.
Cheers
Philip
Philip
1985 Plus 8 four seater
Malone F1000 - track car
Gin Offline
You were correct the wheel nut had worked loose, wheels torqued up correctly with no noise, apart from the n/s wheel bearing that needs replacing!
Cheers
George
Hello George
Glad it's sorted. Took me nearly 2 years to work it out during which time I replaced half axles!
Cheers
Philip
